Suspension Lower your MINI for only 19.99
Old Mar 16, 2006 | 01:12 PM
MotorMouth's Avatar
MotorMouth
http://kalecoauto.com/index.php?main...products_id=11
note: may not be compatible with 16" rims with stock tires.
There are also many hard to find parts on this site.
Old Mar 16, 2006 | 01:38 PM
BLIZZ's Avatar
BLIZZ
There you go again......why didn't I think of that!
I guess I am just not good at thinking outside the box.
Old Mar 16, 2006 | 01:40 PM
Motor On's Avatar
Motor On
I tried it but it doesn't do anything....I am using s-lites w/ runflats can you give some advice or do I have to spend the $$$ to do it the old fashioned way?
Old Mar 16, 2006 | 01:45 PM
MotorMouth's Avatar
MotorMouth
Please read the note. May not be compatible with rims of 16" or larger running the stock tires
Get yourself some good sticky non runflat rubber and these will work perfectly for you =)
Old Mar 16, 2006 | 01:48 PM
Motor On's Avatar
Motor On
BLAST!!! Always too good to be true!( )
Old Mar 16, 2006 | 02:30 PM
blacknblue's Avatar
blacknblue
Photographer / Beer Dude
Compatible with 16" running Toyos though.
Trust me, I have one of those on the rear passenger side right now.
Old Mar 16, 2006 | 03:35 PM
MotorMouth's Avatar
MotorMouth
That's yer problem! You need to apply them to ALL 4 tires or you will look a bit funny.
Old Mar 16, 2006 | 05:30 PM
kenchan's Avatar
kenchan
why don't you just remove the wheels and tires for the ultimate in lowering?
free
Old Mar 16, 2006 | 05:39 PM
gmcdonnell's Avatar
gmcdonnell
Actually, wouldn't the ultimate lowering job be to bury one's MINI?
Old Mar 16, 2006 | 05:57 PM
lhoboy's Avatar
lhoboy
It's even cheaper to remove the Schrader valve stems. Works on runflats as well. The ride's a bit stiff for the open road but works great for boulevard cruising.
Old Mar 16, 2006 | 07:31 PM
MotorMouth's Avatar
MotorMouth
free
I've seen those cars on the street before but it might've been too low cuz it looked like someone then tried to make em a bit higher with wooden blocks...
jeremy_reyes94
Sep 6, 2019 07:53 AM
flredmini
Apr 5, 2016 06:21 AM
nomar116
Aug 12, 2015 05:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
