Navigation & Audio AUX input....not needed
Old Mar 1, 2003 | 05:10 AM
hawk2005's Avatar
hawk2005
This is my first post in these forums...
I read alot comments about how ther could be an AUX input in the upcoming models..
FM TRANSMITTER
this things sends an FM signal to the radio, so u could connect ur ipod or whatevr with much cable....
though not sure if its quality si that good, i think $90 is a good deal......?.......
Old Mar 1, 2003 | 05:29 AM
greatgro's Avatar
greatgro
I don't think those FM transmitter things are very good. Besides, I don't think it should more or much more than $90 to have an AUX jack wired.
Old Mar 1, 2003 | 08:20 PM
TheBluePotato's Avatar
TheBluePotato
Moving to audio forum.
Old Mar 2, 2003 | 10:01 AM
hawk2005's Avatar
hawk2005
Rspeed sells an AUX input kit for $100...
RSPEED
Old Mar 3, 2003 | 08:22 AM
Loren's Avatar
Loren
This is the Blitzsafe adaptor. It requires (I think) that you plug it in in the back of the mini to the CD Changer connections. Then if you wanted an aux input in the front (an mp3 player etc) you'd have to run a wire back up to the front, as well as get an adaptor to convert the RCA connections to a minijack connection. A lot of mucking about.
I'm waiting for the adaptor from Mini, now long long overdue. See the forums on miniusa owner's lounge.
PS: FM Transmitters are horrible in quality, at best only a temporary solution.
Old Mar 3, 2003 | 08:36 AM
nfo's Avatar
nfo
FM TRANSMITTERS are a waste of money!
i learned the hard way......
Old Mar 3, 2003 | 09:12 AM
wwwebb's Avatar
wwwebb
AUX input is the URL for the accessory
Old Mar 3, 2003 | 09:15 AM
Mister_S's Avatar
Mister_S
hawk2005,
Welcome to MCO!
An FM transmitter will work fine if sound quality is not important to you. But a digital music source, even MP3, has far superior sound quality to FM broadcasts; more bass, more highs, less distortion and noise. The same song sounds much better on a CD than when you hear it played on the radio right?
When you listen to the MP3 through the FM transmitter, the signal quality gets reduced to that of an FM broadcast. Since the signal comes from within your car, it will be as good as a very strong FM station, but no better.
A direct low-level connection will give much cleaner results from sonic standpoint (although not as easy an install). Either the Blitzsafe product through the MINIs CD changer hook-ups or the pending factory adapter will provide this kind of connection. The factory option, if it ever arrives, should be a very easy install as I believe it plugs into the back of the stereo in the dash and runs into the glovebox.
Cheers and good luck,
James
Old Mar 3, 2003 | 08:29 PM
hawk2005's Avatar
hawk2005
I was really wondering about the quaity, glad that was bashed enough, cuz i was thinkin of buyin it....
rite on......
BTW, FM quality isn't that bad, is it....??
Old Mar 3, 2003 | 08:46 PM
nfo's Avatar
nfo
you won't realize how bad fm quality is until you own a blitzsafe...
i couldn't stand using the fm transmitter, sounded like garbage!
i'm not kidding!
W0TM8
Dec 19, 2019 07:50 AM
penguinhomey
38
Jul 7, 2019 09:24 PM
surfblue
Oct 24, 2018 01:20 AM
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
Aug 12, 2015 01:24 PM
