track day prep
Old Mar 7, 2006 | 11:37 AM
Profpatpending's Avatar
Profpatpending
track day prep
track day coming up soon does anybody recommend a coolant flush,
there is 36k miles on her and as far as I know never been changed,
so what is the correct mix 50/50 water/antifreeze?
also where is the coolant bleed point?
Old Mar 7, 2006 | 11:41 AM
mbcoops's Avatar
mbcoops
Besides just coolant, any other important track day prep items we should know about?
mb
Old Mar 7, 2006 | 11:54 AM
Profpatpending
well my prep is going to be
1/change brake fluid
2/possibly change coolant
3/ change oil and filter just to be safe
4/check tyre pressures
5/check and torque up plugs
6/wash car polish windows
anybody any other suggestions
Old Mar 7, 2006 | 12:32 PM
apexer's Avatar
apexer
Add/Torque wheels before every track session
Old Mar 7, 2006 | 12:53 PM
gt6's Avatar
gt6
Yes, definately torque the wheel bolts. You also will want to check the brake pads. The last thing you want is to run out of pad when your diving into a corner while quickly closing in on that expensive car in front of you!
Old Mar 8, 2006 | 09:16 AM
D_Nyholm's Avatar
D_Nyholm
I would also suggest bringing a second set of brake pads with you. You never know how much brake you can go through until you do it. It is better safe than sorry!! Obviously, bring enough tools to change them at the track!!
Also, some brake fluid and the ability to bleed them at the track if you boil your fluid or wear your pads down dramatically.
Another obvious one is to clean everything out of all the crevises/junk holders before you go to the track. Clean out the papers in the glove box, change in the cup holders, lift up all the mats and clean out under them, etc...
Old Mar 8, 2006 | 10:12 AM
ahamos's Avatar
ahamos
Coordinator :: River City Minis
In addition to checking your pads, you should keep an eye on your rotors.
Old Mar 8, 2006 | 10:25 AM
mini33's Avatar
mini33
Hi, If you check around, you will find it's not a good idea to use any antifreeze in your car. If it overheats the other cars are in big trouble. Many driving clubs do not allow it, use water wetter, liquid ice etc...
Old Mar 8, 2006 | 10:27 AM
FlynHawaiian's Avatar
FlynHawaiian
you are usually required to change your brake fluid every 6 months according to the bmwcca rules
Old Mar 8, 2006 | 10:46 AM
haulinS's Avatar
haulinS
FWIW, this is the tech inspection sheet I used for the Phil Wicks driving academy (hope the link works)
http://mail.google.com/mail/?view=at...71eb9d43fbcfc4
Old Mar 8, 2006 | 11:23 AM
onasled's Avatar
onasled
Wow, never heard this before. I'm not sure that any DE requires removal of antifreeze. Who requires this?
Old Mar 27, 2006 | 09:19 AM
mini33's Avatar
mini33
From Europencarweb QUICK GOOGLE SEARCH: I hope this helps...
http://www.europeancarweb.com/projec...c_projgolfpt2/
<<Most racing organizations prohibit the use of anti-freeze in track cars--it's very slippery and takes a long time to dry. I emptied the radiator and refilled it with filtered tap water, throwing a bottle of water-wetting agent and corrosion inhibitor into the cooling system to keep things cooler and help prevent corrosion of the VW's aluminum head...>>
Many DEs often do not enforce this unless there is other races the same day...
rtk90
Aug 29, 2019 09:08 AM
PelicanParts.com
Sep 9, 2015 01:42 PM
PelicanParts.com
Tires, Wheels & Brakes
Sep 9, 2015 01:37 PM
PelicanParts.com
Car Care Products
Sep 9, 2015 01:35 PM
PelicanParts.com
Accessory Products
Sep 3, 2015 08:54 AM
