Suspension Lube or no lube
Old Feb 24, 2006 | 07:03 AM
adis_daddy's Avatar
adis_daddy
Lube or no lube
Going to install Helix lower control arms on my 04MCS. Distributor states that lube is not required but I can if I want.
I'd like to hear from the experienced wrenches. If lube should be applied what kind works best for this application.
Old Feb 24, 2006 | 09:19 AM
meb's Avatar
meb
What exactly are you lubing?
Old Feb 24, 2006 | 10:00 AM
CoryB
If they're using urethane bushings, lube the wheeeee out of them or they'll squeak like crazy. If they're rubber bushings then don't worry about it.
Old Feb 24, 2006 | 10:35 AM
kenchan's Avatar
kenchan
is that a helm joint? if so, i don't usually lube them. im using control arms
from stillen on my other car and no noise, no issues.
Old Feb 24, 2006 | 03:41 PM
adis_daddy's Avatar
adis_daddy
Helix uses a heim joint. The bushings must be urethane because they aren't rubber. I think I'll blast off a note to Helix. See what they recommend.
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
David.R53
Sep 13, 2015 03:44 PM
wildwestrider
Sep 4, 2015 06:25 AM
Sep 3, 2015 03:01 PM
minipopkart
Aug 13, 2015 05:22 AM
