coolant replacement..
Old Feb 20, 2006 | 03:46 PM
chiquivw's Avatar
chiquivw
i need to replace the coolant. on a 2004 "s" ..where do i drain it from? and would PRESTONE brand do? and are there a tricks that i should know of.
Old Feb 20, 2006 | 04:29 PM
kapps's Avatar
kapps
Do a search.
Here are the basics (the Bentley manual is helpful if you plan on doing much with maintenance):
Take the cap off the expansion tank and unclamp the lower radiator hose from under the radiator (drivers side). That will drain the coolant from the radiator and expansion tank. The engine block has a drain but it's pretty much impossible to get to. Once the coolant stops flowing from the radiator, re-attach the lower hose and fill up the coolant reservoir. If the engine is warm, the coolant will start flowing into the radiator; if not, it'll just sit in the expansion tank (thermostat closed). With the expansion tank full (and cap on), start the car and let it warm up. You can open it up if you need to add coolant but be careful of hot gases. There is a bleed valve on the upper radiator hose infront of the engine. Use a big screwdriver to loosten it and purge the air from the system. Do this until only liquid flows out.
Have someone keep an eye on the coolant temp gauge (I did mine with the cap off the reservoir by accident and the lack of pressure in the system caused the temp to go higher than normal). I followed the Bentley manual but they didn't mention anything about having the car warm so I was expecting the coolant to flow from the expansion tank to the radiator on a cold car...which it didn't. They said something about a 2nd bleed valve that would let the coolent into the radiator that I could not find (all the pics were on a Cooper). I also didn't know if I should have the cap on or not when I started the car. When fluid wasn't flowing and the temp gauge read 2/3, I turned the car off and tried again. With the cap on, everything went fine and I was able to bleed the system.
I used Prestone All Makes All Models. It's silicate free and shouldn't harm anything. I also added some Water Wetter.
This would be a great how-to for any of you who know what your doing. There really isn't any solid info on the right way to flush the coolant. I know Randy is busy so maybe someone else can do it.
Old Feb 20, 2006 | 05:19 PM
chiquivw's Avatar
chiquivw
way to go "kapps" you tha man .. you have friends in sunny south florida,
on my way to the garage,i can smell the grease already :-) yeahbaby.. minisofmiami.com
Old Feb 20, 2006 | 06:02 PM
skuzy's Avatar
skuzy
anyreason why u would want to do this?
Old Feb 21, 2006 | 05:05 AM
chiquivw's Avatar
chiquivw
36,000miles in south florida heat, yeah it think is time .plus i am on my way to the 11th annual mini cooper event feb.24,25,26. in jacksonville fl. called the spring thing.it"s a 6hour drrive no need to over heat.. PS: come on down and get away from that nasty cold. enjoy some of our warm wheather..
Old Feb 21, 2006 | 11:03 PM
002's Avatar
002
Your temp probably went so high because of air in the system, not the cap. The cap with pressure helps increase the coolant's boiling point. Open the bleed valve when filling the system and it should be ok. Also turn the heater to hot on manual systems or front defrost on auto systems to flush out and bleed the heater core.
Old Feb 22, 2006 | 12:14 AM
UKSUV's Avatar
UKSUV
Cooper's have 2 bleeder screws. MCS's have 1
Old Feb 22, 2006 | 07:20 AM
kapps's Avatar
kapps
Yeah, that's what I was doing. I had the bleed screw open, full heater, and the cap off but I was getting no flow through the upper hose. I actually had the bleed screw comletely off at one point but nothing was flowing. I later assumed the problem was that the engine was cold and the thermostat was closed so no coolant was allowed to flow from the expansion tank into the system. It got a little scarry but after I shut the car off and started it again, everything started to work like I was expecting. Next time, I might just take a funnel and fill the system partially through the bleed screw.
Old Feb 23, 2006 | 09:14 PM
ScottinBend's Avatar
ScottinBend
Wouldn't the dealership do this for you? I just complain about having "mucky brown" coolant and my dealer flushes out my system for me.
Old Mar 31, 2006 | 11:17 AM
MINIotaple's Avatar
MINIotaple
Can you mix coolant? That is, can I use prestone to top off the coolant from the factory?
Old Apr 1, 2006 | 10:00 AM
k-huevo's Avatar
k-huevo
Distilled water will be ok for low surge tank levels. Only add to a level between the markers, not to the top of the tank.
Old Apr 1, 2006 | 06:04 PM
kapps's Avatar
kapps
I've mixed Prestone All Makes All Models with BMW stuff. It's silicate and Phosphate free so it should work fine.
Old Apr 29, 2006 | 09:16 AM
pooch1's Avatar
pooch1
See my gallery all sorts of pics of process.Good luck.Ps lifting right rear of car up gets most of coolant out.Just a little trick I learned in the process.
Old Apr 29, 2006 | 10:34 AM
k-huevo's Avatar
k-huevo
And, if you take the radiator support off, tilt the radiator towards the bottom opening all of the remaining coolant in the radiator will come out. Also, grabbing the hose from the thermostat housing forcing it as low as possible will siphon off more coolant, ditto for the water pump hose.
Draining and refilling most of the coolant is not a substitute for radiator cleaner and flush but done at least yearly will clear up the dreaded brown coolant syndrome.
Old Apr 29, 2006 | 08:32 PM
002's Avatar
002
wrong
They have two. Find the top right corner of the intercooler (closest to the driver) and look directly down. You will see a shiney 10mm head bolt. that is the second bleed screw.
Old Apr 29, 2006 | 09:29 PM
namwob's Avatar
namwob
Sure enough. Follow the heater hose from the waterpump. It attaches to a pipe with a bleedscrew. Thanks
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
vulkandino
Oct 31, 2015 08:29 PM
navybsn
Oct 4, 2015 03:27 PM
point665
Sep 29, 2015 12:41 PM
silence2-38554
Sep 28, 2015 12:19 PM
