Navigation & Audio Output Jacks for Amp?
Old Feb 17, 2006 | 11:15 AM
Beto's Avatar
Beto
Does the head unit have output jacks and switched 12v for aftermarket amplifiers? Or am I going to have to install another head unit just so I can put in a subwoofer?
Old Feb 17, 2006 | 03:06 PM
shankrabbit's Avatar
shankrabbit
depends how you want to do it and what system you have.
i say depends "how" because i can honestly tell you that, no, there is no specificly labeled "sub" output on the HU.
here is a pic of the back of the HU (kinda dark, sorry)
however, within a next two weeks (when I get my bonus from work) i'm going to try to install one using the H/K system by stealing the low freq. rear speaker leads which go from the HU to the H/K amp... and jacking those into a sub amp.
I'll post pics and tutorial (and if it works or not) on my site when I get around to it. (drop you a PM too if you want)
Old Feb 17, 2006 | 03:13 PM
The MINITOR's Avatar
The MINITOR
It works if you dont have the KH system, all you need is a high level converter (aka line out converter). They cost $20-$50.
I don't know much about the HK system except that it is much trickier to work with.
Old Feb 17, 2006 | 03:24 PM
shankrabbit
KH - HK
yeah, i have a feeling me wiring a speaker line route from the HKamp to the sub amp is going to present some interesting, unforseen, problems.
in my head it works great
*then again, so does having 16 imaginary friends:impatient
Old Feb 17, 2006 | 03:46 PM
The MINITOR
Shankrabbit search threads for info on this, others have tried and had problems and eventually found solutions I believe.
Old Feb 17, 2006 | 03:51 PM
not-so-rednwhitecooper
Originally Posted by shankrabbit
KH - HK
I had it setup like that on my cooper for all 7 months i owned it.
No problems whatsoever. I used some of the wiring riht off the amp, it worked out nicely.
make sure you wither use a good wire tap or solder them, its a royal PITA to take it all back apart to fix one loose wire!
OutMotoring
Mar 3, 2017 06:29 AM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Filmy
Sep 7, 2015 08:27 PM
