Navigation & Audio will a harmon kardon sterio work in a non h/k setup
ok i have a 02 mcs with no h/k setup and want to tradev stereo head units with my freinds 05 stereo with h/k
will it be a plug and play operation or will the two stereo head units not work when reinstalled
he is planning to get rid of his stereo anyway so i thought a trade would rock if possible
thanks so much
chris
thanks so much
chris
you could, but, imho, i wouldn't recommend it.
right now all of the wiring for the speakers comes off of the HU. If you wanted to upgrade to the H/K system you would have to do the following:
a) Buy the HKAmp and Speakers
b) route all speaker wiring to the back right of the car
c) wire the HU and HKamp together with all new wiring
d) replace all speakers
e)(not for sure) have some sort of reprogramming done on the HU since i believe the signal to the Amp is digital whereas right now the HU is set to send analog to the speakers
I would recommend just replacing the HU with a nicer one with more power... then you wouldn't have to worry about re-wiring everything.
no i dont want to upgrade to a hk system i just want a stereo that i can get a aux inpute for and a stereo that plays mp3
i dont care about the hk system and frankley i plan on wiring up my own system and ditching the stock speakers also dont want to swap the sterio since i have the multi funtion wheel and need my controlls
the head unit works good enouf for me and with better speakers will be all i need
i dont care for the sound of the hk system(to much bass), i just wanted to know if i swap a non hk stereo with a hk stereo head unit if it will work and all thats all
from the last post it sounds like your saying it wont work and one says it will
if it will thats all i need i jusst didnt want to go thru the work of swaping it out if it wont work
thanks again for your guys help
ahh... i get it now.
from what i understand the HU for both the H/K and the stock are the exact same. i've read, however, that the HU has a low output and you may have to get an additional amp to supply enough power to the better speakers to produce a good sound.
Been There Done That
A friend of mine put the HK radio from my 05 into his 02 s. The wiring harness is exactly the same. You pick up the ability to play MP3's and WMA's, and you can add the aux in plug. here is no aftermarket amplifier needed. A 20 minute job at tops.
also one more queschin i heard it long ago so i dont know if it still aplies but is their a code you have to punch in the sterio once its removed from the car or will it work regurdless
cause i dont have one never came with my manual so dont know
No code needed
just plug and play!
Dec 23, 2015 10:36 AM
Powershift
Aug 16, 2015 05:14 PM
Drivetrain Won't hold idle after work performed
Lt. Dan
Aug 10, 2015 08:23 AM
