Misfire/Plugs
Old Feb 14, 2006 | 11:26 AM
Johan's Avatar
Johan
Misfire/Plugs
I was coming home from SC yesterday (To VA). The traction controll light was on, but that's normal I get a overboost code often so I didn't pay it any mind. When I got on the freeway I was slamming through the gears, as I usually do, when I got to 5th I had a total loss of power. The Check engine light started blinking. I got of on the next exit and hooked up the code reader, misfire on cylinder 1. So I let the car sit and started it up, ran fine so I got on the highway and it started acting up again and went into limp mode. Checked the codes again and cylinder 3 and 1 were misfiring. So I thought maybe bad gas, but I was on 1/2 a tank, the first half was fine?? Anyway put in octane boost and got the rest of the way home without any problems, as long as I used cruise controll and didn't get in the throttle. Today after work I got on it and in 3rd gear I started to misfire again, so I pulled the Plugs and here is what you see. These are the Beru Ultra-X Platin UXF79P (Colder) with less than 7,000 miles. I just put the stock plugs back in but havn't done any testing yet...Any ideas?? Thanks -- Johan
Attached Thumbnails Misfire/Plugs-plugs.jpg
Old Feb 15, 2006 | 01:59 PM
Johan's Avatar
Johan
Ok the stock plugs are in and everything is fine...don't know what that was all about. I think I'm just going to get a set of NGK's single ground one colder and call it a day...they have them at advanced auto for $7 a piece -- Johan
Old Feb 15, 2006 | 03:13 PM
minibeel's Avatar
minibeel
Coordinator :: PDX MINI
dang... #3 cracked
Maybe you got funky plugs? I'd call Beru and complain. Especially if there is no problem with other plugs...
dan
Old Feb 15, 2006 | 03:27 PM
bryan1970's Avatar
bryan1970
if it happens again with the new plugs one thing to look at is the ignition coil. maybe you have a bad coil and cyls 1 and 3 share the same coil pack. but it looked like no. 3 plug was cracked. it seems like you have something else other than a coil going out. how much boost are you running maybe the cyl temps are too hot for those plugs.
Old Feb 15, 2006 | 10:25 PM
neilgj's Avatar
neilgj
Is it possible the plugs were over-torqued on installation? That can cause the ceramic to crack.
Old Feb 15, 2006 | 11:25 PM
002's Avatar
002
Actually, 1,4 and 2,3 share coils.
I just changed to ngk plugs and magnacore wires and the has never run better.
Old Feb 16, 2006 | 11:30 AM
ChocolateAZ's Avatar
ChocolateAZ
I had the same problem with my Denso's. Misfiring. Got home and the center electrode was gone. This happened one number one cylinder. I am running a Pilo coil and Nology Hotwires. Keep in mind that our ignition system is also called a waste spark. So two cylinder sparks fire but there is nothin g to burn in one of the cylinders.
Hope this helps and good luck!
Old Feb 16, 2006 | 11:36 AM
flyboy2160's Avatar
flyboy2160
choc,
how many miles were on your densos when this happened? i just put a set in.....
thanks
Old Feb 16, 2006 | 12:51 PM
bryan1970's Avatar
bryan1970
oops sorry for the wrong info. i my head was still in GM mode lol. GM v6's share 1 and 3
