Suspension Help with "seat of pants camber"
Old Feb 12, 2006 | 07:24 PM
COR BLMY's Avatar
COR BLMY
Hi all, I am going to purchase a camber tool but not right yet.
I have H&R springs (1 inch drop) and adjustable upper and lower controll arms.
Could one of you who knows their camber please use a squair / right angle and measure with the 90 on the ground and, tell me what your known camber is and what the measurement to thre upper edge if the rim is.
I set it at 3/4 inch just eyeballing it
I'll take it to the shop / get the tool just wanted to be in the ball park.
I thought about going to the dealership but that could look odd
Old Feb 13, 2006 | 01:38 AM
BFG9000's Avatar
BFG9000
The traditional way of measuring camber without a gauge is to subtract the distance to the lower edge of the lip from the distance to the upper edge when using a square on the ground. The math is (Difference/(3.14159 * 2 * Height)) * 360 = degrees. For example if the difference is 0.75" and you have S-lites which are 18.5" in height, that works out to 2.3 degrees, negative I hope. Which should be close enough to drive to a shop.
Note this method works even if the ground is not level, unlike a gauge.
Old Feb 13, 2006 | 04:44 AM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
With having both the upper and lower arms you should be more concerned about toe. The wrong toe setting can wear out your tires in a few miles. Try to match the arms to the stocks ones as a start.
Old Feb 13, 2006 | 05:22 PM
COR BLMY's Avatar
COR BLMY
Thank you ... I really do appreciate both of your input
Colt45Magnus
Aug 27, 2024 05:03 AM
Supertractor3
Apr 7, 2017 11:16 AM
sir5150
Oct 6, 2015 05:25 AM
MINI_42
Sep 16, 2015 02:01 AM
SeattleF56
Sep 3, 2015 03:01 PM
