Interior/Exterior 02-04 aftermarket taillights in 06
Old Jan 31, 2006 | 01:52 PM
UncleFester's Avatar
UncleFester
Found a set of aftermarket taillights I like but acc to vendor they only are available for 2002-2004 models. What difference(s) are there between 2002-2004 and 2006 models? Wanted to ask before risking it. Thanks
Old Jan 31, 2006 | 02:04 PM
sagworks's Avatar
sagworks
running with scissors
Super easy install. notsoredandwhite cooper has an install guide on his website which was super easy to follow.
You will need to get 04 bulb sockets (from MINI $10 for the set). The only thing wrong in the tutorial, is it took about 20 min. total.
These are 02-04 taillights from ebay.
Old Jan 31, 2006 | 02:21 PM
wikedgolf's Avatar
wikedgolf
nice.. i was thinking the same thing!
Old Feb 1, 2006 | 01:37 PM
Pir8 97's Avatar
Pir8 97
What about the reverse light? 02-04 didn't have it integrated in with the tail lights.
Old Feb 1, 2006 | 04:26 PM
sagworks's Avatar
sagworks
I have reverse lights in my taillights. The center light (which is now white) is on when I reverse. I know I have some super bright reverse lights now and super bright rear turn signals.
Old Feb 1, 2006 | 04:31 PM
not-so-rednwhitecooper
Are you sure its the center light? It should be the top light, the old fog light, that is your reverse light. The center should still be a turn signal.
Old Feb 1, 2006 | 05:35 PM
sagworks's Avatar
sagworks
I could be wrong, it could be the top light - It is cold outside, so I am not going to check!
Old Feb 2, 2006 | 05:27 AM
BoCRon's Avatar
BoCRon
I've been dying to change out my taillights, to continue my all black/white/silver theme on El Kabong. Could someone tell me if either of these lights is better than the other, or are they the same brand just not noted?
http://cgi.ebay.com/ebaymotors/02-03...35259944QQrdZ1
http://cgi.ebay.com/ebaymotors/02-05...34866457QQrdZ1
Thanks, and thanks for the how to link, I'm thinking I may just try this myself!
Annette
Old Feb 2, 2006 | 05:44 AM
Rev. Limiter's Avatar
Rev. Limiter
I would be wary of buying from anyone on ebay with a negative feedback such as theirs. One has had 27 in the last month with 229 in the last 6 months. The other has had 34 in the last month with 162 in the last 6.
Caution called for here?
Old Feb 2, 2006 | 07:15 AM
sagworks's Avatar
sagworks
I bought those exact lights from 'powerimport' (the second option) No problems, pretty fast shipping, well packed. I took the chance buying from someone with some negative feedback and it worked out with my purchase. No complaints with my purchase.
BOCron - I am doing the same thing, I am trying to get rid of as much red as possible. Clear third brake light is next for me, and I'll probably do the clear fog light assembly too. (with stealth bulbs)
Old Feb 2, 2006 | 07:30 AM
Pir8 97's Avatar
Pir8 97
Like mine I only have the red reflectors to keep it legal. I'm thinking about tinting them to hide them a bit.
Old Feb 2, 2006 | 07:51 AM
sagworks's Avatar
sagworks
Pir8 97 - yes!!! I do want to change out the side light/reflector unit with clear ones like you did too. I think that looks great on a black car! I have some 1/2" x 4" small rectangles on the back bumper (plastic part) in an attempt to be legal.
OutMotoring
Mar 3, 2017 06:29 AM
Doc Pain
Oct 28, 2015 07:09 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:50 PM
Alpha Motoring
Oct 1, 2015 10:30 AM
