R50/53 Emergency help!!! how to close the bonnet
Old Jan 28, 2006 | 06:55 PM
mondsiu's Avatar
mondsiu
i can't close the bonnet completely !!!
pls help meeee :impatient
Old Jan 28, 2006 | 07:00 PM
mondsiu's Avatar
mondsiu
plspslspl somebody help
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Release it, open it, and then drop it from a foot or so.
Has it ever closed? Why won't it now? Make sure nothing is under there - tool, clothing, rodent, etc.
Randy
Old Jan 28, 2006 | 07:02 PM
mondsiu's Avatar
mondsiu
it's my first time open it..
won't close when i drop it down, it goes bac to that position where u need to pull that lever to open the bonnet
Old Jan 28, 2006 | 07:09 PM
Tarzan's Avatar
Tarzan
Some things to try:
Work the bonnet pull lever a couple of times to be sure it moves freely.
Look at the latch mechanism under the hood. Is it in the 'catch' position or in the 'lock' position, preventing it from catching with the opened bonnet above?
Try flicking the latch mechanism a couple of times with your fingers to be sure it's not stuck.
Drop the bonnet from a bit higher, or give it a more swift downswing (don't go crazy though).
Once down, press firmly downward on both headlamps at the same time.
Old Jan 28, 2006 | 07:10 PM
BoCRon's Avatar
BoCRon
Mine seems to take a bit of a slam when I close it. Open it back up all the way, then lower it to at least a foot above closing and give it a push down.
Annette
Old Jan 28, 2006 | 07:13 PM
kenchan's Avatar
kenchan
i usually drop it from about 2 feet and continue to push down on the grill
gently as it locks. mine is a bit tough to close too.
Old Jan 28, 2006 | 07:18 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Don't be shy to let it drop from 1-2 feet to close it.
The MINI hood, with the headlights, is a bit hard to close without a bit of "help". Let gravity do his work lol
Keep us updated.
Old Jan 28, 2006 | 07:19 PM
mondsiu's Avatar
mondsiu
shtsht no it can't closeeeee noooooo!!!
Old Jan 28, 2006 | 07:44 PM
BoCRon's Avatar
BoCRon
Can you post a pic of it all the way open and after you try to close it?
Annette
Old Jan 28, 2006 | 07:45 PM
mondsiu's Avatar
mondsiu
okkk
Old Jan 28, 2006 | 07:52 PM
mondsiu's Avatar
mondsiu
as u can see it dosn;t close/.....
mondsiu's Avatar
mondsiu
Old Jan 28, 2006 | 07:53 PM
mondsiu's Avatar
mondsiu
mondsiu's Avatar
mondsiu
Old Jan 28, 2006 | 07:56 PM
Bakerman's Avatar
Bakerman
Wonder if the cable is frozen. Happened to me, but with the opposite problem, couldn't open it. Took them all day to replace it.
Old Jan 28, 2006 | 07:58 PM
Aviators's Avatar
Aviators
I had the same thing happen where the gap on the driver's side w/ the bumper was VERY large.
I just needed to push down HARDER as I closed it.
I even asked at mini and their comment was "don't be shy, CLOSE the hood don't dance around it hoping it'll lock"
DrDiff's Avatar
DrDiff
Coordinator :: Northwest Indiana MINIacs
I once didn't drop MIB's Bonnet from high enough. The driver's side latched and the passenger side didnt. I had to go to the passenger's interior and pull the release. That allowed the drivers side of the bonnet to release so that I coud pull the lever to release the bonnet and raise it. Now I always make certain to drop the hood from 2 feet or so. I also give it a little push just before releasing.
Hope that this helps you!
Old Jan 28, 2006 | 08:06 PM
mondsiu's Avatar
mondsiu
OMGGGGGoooddd
I shut it REALLLYYY hard i slam it like crazy and it shuts HAHAHAHAHAHAA
thx for all the work guys
PROBLEM SOLVED i am going to drive it now
THXTHXTHXXXXxxx u guys a really gddd , very effective
Old Jan 28, 2006 | 08:15 PM
Jersey_Bill's Avatar
Jersey_Bill
***hey, everybody - wanna make a bet that Mondsiu NEVER opens his bonnet again ???? ***
Bill
kenchan's Avatar
kenchan
now your headlight aim is out of alignment.
Old Jan 28, 2006 | 08:21 PM
mondsiu's Avatar
mondsiu
omggg i hope nott anyway thx a lot (really)
Old Jan 28, 2006 | 09:23 PM
addamaniac's Avatar
addamaniac
Well, if it doesnt latch completely, and youve never opened it before, then the hatches must be a little too far down. they are obviously within range for the bonnet clips to reach them(otherwise it wouldnt have ever been closed)
Easily solved. they are not hard to re-adjust. MINI should be able to do it for you also. it would take all but a few minutes to do it yourself. I believe they are 13mm bolts. just loosen a bit, and raise up the hatches...simple as that..
I'm curious as to whether this works for you...let me know if you try it
Addam
Old Jan 29, 2006 | 05:49 AM
pooch1's Avatar
pooch1
I dunno I never have to slam it or push on hoods,I drop from 2 feet.Most car companys dont advise leaning on hoods.The only ones Ive seen with this problem are ones with strut bars that interfere with hood insulation.
Old Jan 29, 2006 | 05:55 AM
Zman's Avatar
Zman
mine doesn't close from a drop either, gotta push
down on/near the headlamps while the hood is closing. several others have posted the same observation
