MCSa no M1 in SD
Old Jan 27, 2006 | 08:09 PM
MiniKJ's Avatar
MiniKJ
MCSa no M1 in SD
Hello. I searched through the forum and only found one review mentioning the MSCa won't downshift to M1 at full stop. I tried using the SD tonight and noticed it did that everytime. I had to push the stick to get to M1. I don't believe this little 1.6 does 2nd gear start at stops (like what you could do in a Corvette), especially it's in SD which is supposed to give full power launch in 1st gear. Does anyone else with MCSa have the same experience? Thanks.
Old Jan 27, 2006 | 08:11 PM
FlynHawaiian's Avatar
FlynHawaiian
in my x3 it does, should do the same in the mini.
Old Jan 27, 2006 | 09:35 PM
Maximusmini's Avatar
Maximusmini
not only does the MCSa do this, but the automatic coopers do also.
Old Jan 27, 2006 | 10:30 PM
Rawhyde's Avatar
Rawhyde
Why would anyone design a car with an automatic transmission so that it doesn't use 1st gear? Lexus pulls that trick too. Why brag about having a 6 speed automatic when you're only using 5 of the ratios? I think it's the wrong thing to do, but MINI isn't the only culprit. This looks like a good thing for the aftermarket "chip" makers to address.
Rawhyde
Old Jan 28, 2006 | 12:50 AM
Maximusmini
actually it can be gas mileage related AND if you press the pedal all the way down, it will downshift into first for more torque. if you think about it, it's really a good idea. especially in a decade like now. we need to find other sources of energy, usually best if they are renewable.
Old Jan 28, 2006 | 07:43 AM
Rawhyde's Avatar
Rawhyde
2nd gear starts would be OK if that mode was activated by a "snow" switch or something similar. Mercedes and some other makers do it that way. I still think that automatics should start off in first gear. Especially when in "Sport Drive" mode.
When the driver goes into "sport drive", performance is usually what he/she is looking for.
Rawhyde
Old Jan 28, 2006 | 10:08 AM
Outbackbob's Avatar
Outbackbob
Well that explains the hard downshift to 1st when I punch it from a full stop in SD.
Old Jan 28, 2006 | 11:18 AM
MiniKJ's Avatar
MiniKJ
So, if I purposely downshift it to M1 before coming to a full stop, that shouldn't hurt the engine or tranny, correct? It did feel a bit jerky.
Old Jan 28, 2006 | 11:46 AM
FlynHawaiian
well going from 20mph at 2nd to 1st gear is going to feel a bit jerky. In SD mode, there is a button under the throttle. So if you "floor" the car at a stop light it should go right into 1st even in the "automatic sd" mode. After about 20 launches like this the car should "program" itself to that driving style and should basically always start in first gear. Least thats what my x3 does O_o
Old Jan 28, 2006 | 12:31 PM
Mini Pete's Avatar
Mini Pete
By the way, many auto tranny cars including MINI, BMW, Mercedes, Porsche, etc. start off in 2nd gear. Only if you manually put the car in 1st or accelerate hard enough from a standstill or a very slow speed will the car kick down into 1st gear.
Old Jan 28, 2006 | 12:56 PM
eVal's Avatar
eVal
Yup, all of the recent model step bimmers I've driven and now the MCS does this, I assume as a gas saving measure. The Dinan software I had on my 2000 328Ci cured this and had the car go to first gear at stops, but as of 01 the BMW ecu somehow changed things from what I heard, and people no longer got that benefit from Dinan.
Intially I thought I'd want that upgrade on the MCSa too, but since I find myself in manual mode 99% of the time and shifting on my own with the paddles even more then in the BMWs (well except for the SMG M3 ) I don't feel that I need it. Personally I would advise using the manual mode if you want sportiness, flooring it to tip the kick down mode from a stop is bound to just make you spin your wheels and activate the traction control.
Old Jan 28, 2006 | 03:05 PM
MiniKJ's Avatar
MiniKJ
Thanks guys. This is good to know that it's not something wrong with my car.
Old Jan 28, 2006 | 03:12 PM
FlynHawaiian
nope bmw just "programmed" in some "whussyness" to the car because of fuel savings. BLAH!
ShadyCoop
Sep 8, 2015 04:50 PM
fm.illuminatus
Aug 10, 2015 12:15 AM
mdsbrain
Jan 18, 2006 06:50 PM
BillyB
23
Aug 24, 2005 07:33 PM
mdsbrain
May 26, 2005 09:51 AM
