Oil Catch Can problem?
Old Jan 26, 2006 | 02:38 PM
mdsbrain's Avatar
mdsbrain
Should the fact that my catch can is bulged be a concern? See pic
Old Jan 26, 2006 | 03:38 PM
OldRick's Avatar
OldRick
Have a read on https://www.northamericanmotoring.co...ad.php?t=49645
Note comments by andy@ross-tech
You shouldn't have lots of pressure inside the catch can
- and -
You should have something that withstands fairly high temps and can put up with nasty chemicals like motor oil
Unless it is growing a tumor, it shouldn't swell up - I'd find out why it has, and why it isn't trapping much oil.
Old Jan 26, 2006 | 03:48 PM
chows4us's Avatar
chows4us
Maybe its pregnant
Old Jan 26, 2006 | 04:00 PM
OldRick's Avatar
OldRick
Maybe it's pregnant
Let's not follow up on that thought...
Old Jan 26, 2006 | 04:27 PM
mdsbrain's Avatar
mdsbrain
But it did trap alot of oil. Not enough to bulge the sides out though.
Old Jan 26, 2006 | 04:40 PM
chows4us's Avatar
chows4us
I'm tell ya, its preggers. think of all the other little red catch cans that will be running around under ur bonnet
Old Jan 26, 2006 | 04:44 PM
OldRick's Avatar
OldRick
Your blog said
...I removed the bottom drain plug and hardly anything came out.
If your desire was bling, it really isn't very good bling as it looks now...
For the same money, here's a much better-engineered alternative to replace it: M7 Catch Can or you could go the $30 generic route.
Old Jan 26, 2006 | 04:46 PM
mdsbrain's Avatar
mdsbrain
I need to rewore my blog. I pulled the plastic clear tube first and removed most of the oil and then removed the drain plug. I got some out of both. Less then I thought it held. I do agree that a can like the M7 one being metal is a better can.
Old Jan 26, 2006 | 04:57 PM
OldRick's Avatar
OldRick
I'd ask the vendor to refund or replace it.
Old Jan 26, 2006 | 05:35 PM
mdsbrain's Avatar
mdsbrain
OLDRick could you expand more on this valve which could be blocked? How would I know or how to clear it if it is.
Old Jan 26, 2006 | 05:44 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Could just be a weak spot in the silicone. I'd be happy to replace it. Give me a call! It shouldn't be any big deal until you get the new one. Are you getting a lot of pressure in it? If so, check the coolant to make sure you don't have a head gasket problem - there would be oil in it.
Hope that helps!
Randy
Old Jan 26, 2006 | 05:48 PM
mdsbrain's Avatar
mdsbrain
Thanks Randy! I will talk to you tomorrow.
Old Jan 26, 2006 | 07:26 PM
OldRick's Avatar
OldRick
As to a check valve, I'm not sure if there is one in these cans, or if they use the stock PCV valve, but there is a check-valve somewhere in the path to keep outside air from being sucked back into the crankcase. It lets blowby pressure out (and feeds it back into the intake) but doesn't let outside air back in.
The whole point of the PCV system is to release the dirty air that leaks by the valve seals and piston rings into the crankcase, without letting it get out into the atmosphere as pollution.
If the PCV valve sticks, then the pressure can't get out of the crankcase, and can, in the worst case, blow out the main seals on the crankshaft. Usually the hoses pop off the valve first, but there is always that chance...
Since it is emissions-related, the manufacturer is required by federal law to provide a five-year warantee on it, is my understanding, so I'd take it to the dealer to have it checked.
However, if it is a standard PCV valve as used on most cars, the simple answer is, remove it from the path, and try to blow through it then try to suck air through it. It is just a one-way check-valve, so it should allow you to do one but not the other if it is working correctly. Then it would be good to verify that it is not installed in the wrong direction, allowing outside air in, but not crankcase pressure out.
Old Jan 27, 2006 | 05:39 AM
Wagnbat's Avatar
Wagnbat
Hope that helps!
Randy
I'm willing to bet Randy is correct. MDSBrain just got his baby back from the dealership with regards to a head gasket problem.
Alta have anything to say about this? PM Alta2 here on NAM... Everytime I have, I've gotten good response from them.
Any other record of bulging cans? This is the first I've seen.
Old Jan 27, 2006 | 05:43 AM
mdsbrain's Avatar
mdsbrain
Maybe...but my dealer also mentioned I might be pushing to much boost . I'm not sure which it is. I'll talk with Randy later and I have PMed Alta for their comments.
I am slightly confused as to how to check if there is pressure in the can. The bulged can is bulged when its in or out of the car. Would it of bulged from pressure and stretched the silicon?
Old Jan 27, 2006 | 07:22 AM
Bahamabart's Avatar
Bahamabart
Originally Posted by chows4us
Maybe its pregnant
I'd would be interested in one of the offspring. The adult model is just too expensive.
Old Jan 27, 2006 | 07:44 AM
chows4us's Avatar
chows4us
He could put the babies up in the marketplace but I would bet they would be worth a fortune on eBay!!!
Old Jan 27, 2006 | 08:43 AM
OldRick's Avatar
OldRick
Would it of bulged from pressure and stretched the silicone?
Yep - exactly.
Old Jan 27, 2006 | 10:24 AM
ALTA2's Avatar
ALTA2
Manufacturer
We will replace it also, Randy don't worry about. Most likely it is because the can is seeing boost(which it can take but not normal in the CC install) You might have something hooked up funny. How do you have it hooked up?
Old Jan 27, 2006 | 10:43 AM
mdsbrain's Avatar
mdsbrain
I talked with Randy about the can. He told me something to check on my car and I will. I'm not going to make a fuss about it unless I find something funny.
Edit: The can is hooked up however Randy installs it.
Old Jan 27, 2006 | 10:46 AM
OldRick's Avatar
OldRick
It it worth noting that silicone hose is not rated for containment of oil, gasoline, or toluene, all of which are present in a catch-can. It has little chemical resistance to these liquids.
By the time you change it, your oil will contain several percent gasoline, and if you ever use injector cleaner, it's a good way to get some toluene in there.
For lots more information read this report comparing hose materials...
Old Jan 27, 2006 | 10:54 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Jeff,
I've got it taken care of, but thanks!
I spoke to the "brain" today, and we have figured out that it most likely was related to a head gasket issue he had. With that fixed, the pregnancy should be limited to the one time. We confirmed the vasectomy on his car!
Hope that helps!
Randy
Old Jan 27, 2006 | 12:40 PM
ALTA2's Avatar
ALTA2
Manufacturer
Great! Simple solution just change the head gasket! Just kidding. Keep us posted as to what happens, and let us know if you need a new body.
Kimolaoha
Jul 5, 2023 01:04 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Lschneider
Aug 21, 2015 02:21 AM
M7Speed
Aug 6, 2015 01:48 PM
