Window motor on drivers side
Old Jan 18, 2006 | 09:01 PM
Soul Coughing's Avatar
Soul Coughing
my drivers side window does not work anymore, it is in the most upright position so that when i try to close the door it gets caught on the upper sill. when i press the the down or up button, it just makes a clicking sound for second, coming from the motor, (like when you try to move the window up when its already closed) i took off the inner door and didnt see anything stopping it from moving. does anyone have any troubleshooting help before i schedule an appointment? Think its a sticky sensor?
Old Jan 19, 2006 | 12:04 AM
autopia's Avatar
autopia
I've had both window motors & door locks replaced over the latter part of 2005... not all at the same time. My driver's side window was stuck in the "cracked" position, so I didn't have trouble closing the door. However, the driver's side window will now sometimes fail to "crack" & it's rather unpleasant when closing the door (happens maybe 1 of 75 times). The switch functions fine, so I just bring it down, close the door & put it back up. Definitely something to have dealt with on my next dealer visit. Good luck to you.
Old Jan 19, 2006 | 04:36 AM
petecrosby's Avatar
petecrosby
The problem is caused by carbon build-up on the stator of the motor. This is
a rather common problem and one which I experienced myself last Friday.
The ultimate fix is to either pull the motor, disassemble it, and clean the
stator or to replace the motor.
In the meantime, though, you can turn the key to the second position,
hold the window switch down, and give the inner door panel a couple of serious
whacks with the bottom of your fist (between the two speakers). Then
release the window switch and pusgh it up and down a couple of times.
It freed mine up and hopefully will do the same for yours.
Old Jan 19, 2006 | 04:40 AM
GBMINI's Avatar
GBMINI
As Pete says - the "thump the door panel" technique works well. Just try to coordinate hitting the door panel (just below the little speaker) t the same moment that you click the window switch down.
It should free up the motor for at least a few days ... but eventually you will need a new motor; hopefully you have a bit of warranty left.
Old Jan 19, 2006 | 04:57 AM
pooch1's Avatar
pooch1
Out of warranty see ebay 2 motors 40.00
Old Jan 19, 2006 | 02:50 PM
Soul Coughing
thanks guys, i will go do this now... of course the warranty just expired... so if it doesnt, ill check out the Ebay stuff, cheers
Old Jan 20, 2006 | 09:45 AM
Soul Coughing
it worked!
thanks guys, you made my night, i was very surprised! So could i foresee ably continue hitting this thing indefinitely? Thanks Again!
Old Jan 20, 2006 | 10:06 AM
GBMINI's Avatar
GBMINI
I think the motor will continue to deteriote, and the "time between thumps" will get shorter and shorter till eventually it is permanently dead.
Meantime, glad it's working again!
Old Jan 20, 2006 | 10:16 AM
Big Daddy's Avatar
Big Daddy
I had the same issue, did the "thumping" method for a couple of days, and it seemed to clear up the problem. It has worked fine for 4 months now.
Old Jan 21, 2006 | 04:19 PM
NCO00P's Avatar
NCO00P
heaheahe the thumping mod works for me... its happened to me about 7 times already. and ive also got the motor changed a year ago.
whats with all these problems with mini, there always seems to be something wrong.
Old Jan 21, 2006 | 04:22 PM
GBMINI's Avatar
GBMINI
I cannot claim perfection in any of the MINIs I have owned - but all have been fabulous to drive/own/etc. I have previously owned for example a Lexus that had leaking transmission oil, and a Chrysler that had paint so thin it almost fell off if you looked at it.
"always something wrong" - not true!
maestro39
Oct 27, 2015 02:38 PM
ej
Sep 28, 2015 05:41 AM
one73ronin
Aug 19, 2015 12:36 PM
Redhotz
R55 :: Clubman Talk (2008+)
Aug 14, 2015 05:29 AM
messyjesse96
Aug 12, 2015 05:51 AM
