Drivetrain pulley removal tool
Old Jan 15, 2006 | 07:44 AM
skuzy's Avatar
skuzy
pulley removal tool
Hi Just wondering, with the pulley removal tool , can u use an alta removal tool to install an m7 pulley ? or is it alta removal only works with alta and m7 only with m7 etc?? thanks
Old Jan 15, 2006 | 08:03 AM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
You can install any pulley after removing the stock pulley. The pulley tool is only used to remove the stock pulley. I use the same puller for all my pulley installs, and I've installed Alta,Helix,m7, and mania pullies. Let me know if you have any other questions.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Jan 15, 2006 | 04:42 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
As MINIguru@waymotorworks said, any removal tool will work!
Just make sure the installer knows his stuff, and get the job done right.
And have a great time with your new pulley! MCS should come with a reduced pulley from stock!
minipopkart
Aug 13, 2015 05:22 AM
kpl
Aug 11, 2015 04:52 AM
Lt. Dan
Aug 10, 2015 12:46 PM
