Drivetrain pulley removal tool
pulley removal tool
Hi Just wondering, with the pulley removal tool , can u use an alta removal tool to install an m7 pulley ? or is it alta removal only works with alta and m7 only with m7 etc?? thanks
You can install any pulley after removing the stock pulley. The pulley tool is only used to remove the stock pulley. I use the same puller for all my pulley installs, and I've installed Alta,Helix,m7, and mania pullies. Let me know if you have any other questions.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
As MINIguru@waymotorworks said, any removal tool will work!
Just make sure the installer knows his stuff, and get the job done right.
And have a great time with your new pulley! MCS should come with a reduced pulley from stock!
minipopkart
Aug 13, 2015 05:22 AM
