R52 Convertible drip
Old Jan 4, 2006 | 09:17 AM
chuckyTLC's Avatar
chuckyTLC
Convertible drip
Hi,
I've got an '06 Convertible. When it rains hard, I get a tiny drip from the corner of the convertible top - where the top meets the windshield, on the driver's side. I get about a drop every 15 seconds or so.
I'm used to driving old convertibles, and have always had a drip like this somewhere on the convertible top/windshield seam, but was expecting better from a brand new Mini! Has anyone else experienced this? Is this normal, or a defect?
Thanks!!!
Old Jan 4, 2006 | 09:25 AM
glenberk's Avatar
glenberk
Knock on wood
I've got 2006 MC convertible with, knock on wood, nary a drip. I'd definitely have them "fix it".
Please let us know what happens.
Old Jan 4, 2006 | 09:45 AM
eVal's Avatar
eVal
Yeah, I'd consider it a defect and take it in. Best of luck with it.
Old Jan 4, 2006 | 12:30 PM
V70R's Avatar
V70R
Mine doesn't leak from there, but I've had it in a touchless car wash a few times, and it drips from the spot where the two side windows meet at the top. I'll have it examined at my next visit.
I wouldn't tolerate any kind of leaks on a brand new convertible. I had a 77 mgb that would leak occasionally, but that was almost part of its charm.
Old Jan 4, 2006 | 05:00 PM
Rev. Limiter's Avatar
Rev. Limiter
Suggest you take it in for an adjustment. Nary a drip with mine - even thru some serious showers.
Old Jan 5, 2006 | 05:09 AM
coolbluemini's Avatar
coolbluemini
Mine drips in the same spot after I open the door in the rain or roll the window down and up
Old Jan 5, 2006 | 05:12 AM
Wesmonster's Avatar
Wesmonster
Check the drain...
From previous posts, there's supposed to be a drain hose located inside the A pillars. I'm assuming that it's behind the hole that the pin from the convertible top frame slides into. It's possible this hose might be pinched or plugged. Wish I could find a picture, though, as that's just based on what I've read. I know treating all the rubber on the top will help repel water. Don't accept any leaks, that will ruin floorboards over time. Mine is dry as a bone.
Originally Posted by chuckyTLC
Hi,
Thanks!!!
Old Jan 5, 2006 | 05:51 AM
alpinamike's Avatar
alpinamike
They do not like it when you go through a automatic
Car Wash.
MINI does not recomend high pressure hoses, or touchless, automatic car washes, because the roof will leak there, and on the B pilar. Their adjustments seem not to do the trick, try "gummyflege" thats what MINI calls it. It willl make a better seem and condition the seal.
If you are cheap vasoline will do.
-alpinamike
Old Jan 5, 2006 | 08:46 AM
chuckyTLC's Avatar
chuckyTLC
Thanks everyone! I haven't been through a carwash yet, so I think it's probably going in to the dealer for adjustment... Sadness!
C
Old Feb 15, 2006 | 09:04 AM
Robsreef's Avatar
Robsreef
Mine used to leak over the passenger side front seat. Turns out there was a bad sil on it. My dealership fixed it and there hasn't been a problem yet.
Old Feb 15, 2006 | 09:34 AM
bamatt's Avatar
bamatt
Mine leaked where the 2 side windows meet each other at the top. The dealer adjusted it & haven't had a drop since
Old Apr 8, 2006 | 03:57 AM
CeliaMarie's Avatar
CeliaMarie
are we talking with the doors open or closed?
Mine doesnt drip closed, but open, the rain comes in like dam breach.
Old Apr 8, 2006 | 04:17 AM
snooter's Avatar
snooter
Mr. MOTD
The day I went to trade in my seebring convertible for my Mini convertible, I drove the seebring thru a touchless carwash for the first time. Water came pouring in from both sides, it's was a nightmare. Once outside, during my "mopping" up, the carwash attendent explained how the touchless carwash has sooo much more pressure than the regular one, since pressure is the only way it can remove the dirt.
If you got a convertible, never go touchless. Of course, I only hand wash my Mini
Old Apr 8, 2006 | 01:26 PM
zeusboy's Avatar
zeusboy
I had a slight leak about the passenger side window and took it to the dealer to have them check it out (among a few other things). The service advisor told me that there was an "unannounced recall" on the tops to have them adjusted, so they did it and no more leaking. They said they were just doing this for people who had a problem or complained about it.
Old Apr 9, 2006 | 04:43 AM
Nemesis's Avatar
Nemesis
I have to second that. Are we talking about when you open the door during the rain? My car is dry the whole time but when my passenger opened the door to get in, the seat would get wet. Since we were doing a lot of errands, the door was opened multiple times to go in and out. Every time the same thing..so much so I ended up carrying a rag and having to dry the seat before he sat down.
Looking at it, it looks like there is a seam on the bottom of the convertible top (right above the side windows) that runs the length of it and stops just short of the "A" pillar. You can watch the rain stream track this from the back of the car to front and then down the side window. So when the door is opened the rain enters the car and falls right on the seat.
Does anybody else have this or should that seam be longer and track this rain to the windshield or closer to the “A” pillar?
Old Apr 14, 2006 | 07:44 AM
jf1972's Avatar
jf1972
05 MCSCa with no leaks.(let's hope I didn't jinx it for me.
Old Apr 14, 2006 | 07:49 AM
alpinamike's Avatar
alpinamike
They just put in spacers!
Thats how they fix it, and you can adjust the weather strip rails.
Make sure they "gummy fledge" them
Old Apr 14, 2006 | 09:19 AM
rameeti's Avatar
rameeti
Old Apr 15, 2006 | 06:26 AM
Nemesis's Avatar
Nemesis
Just to be clear. My top does not drip when the door is closed. But when the door is open to get in..then the rain tracks from the top right onto the seats.
Since I had to get my new plates this week (part of Support Group Week 10 and only had her for about 3 weeks) I spoke to the Master SA (I think that's what they called him). He told me this is a known condition even with the Hardtops, Mini knows this and there is nothing he could do right now. He noted it on my account and will notify me if/when there were any service bulletins released.
Is this true? Why only 3 of us see this issue?
Old Apr 15, 2006 | 09:33 PM
neilgj's Avatar
neilgj
I had a drip before my roof was replaced. The drip was from the passenger side corner. The new roof is apparently fitted better and have not experienced any drips even in the torrential downpours we have been seeing here all-too-often, of late.
So what you are seeing is clearly something the dealer ought to look at and fix.
Old Jan 8, 2007 | 01:57 PM
mpbradley's Avatar
mpbradley
Has anyone gotten any satisfactory solution. I have a new car and every time it rains, the seats get soaked from me getting in and out of the car.
Old Jan 8, 2007 | 09:02 PM
Wessy's Avatar
Wessy
Same here, and I just consider it a design flaw. It's an issue I was aware of before I got my MCC, and I got it anyway -- as others have done, I mostly just laugh it off as a quirk of driving an eccentric British car, something of a vestige of vintage sports cars that were far less sophisticated in every way than our MINIs.
Fortunately, it doesn't rain much where I live, and when some accumulated rainwater does fall from the roof onto my seats, it's no real biggie since they're upholstered in cloth. If I had leather seats, on the other hand, it's a design flaw I might not be quite so forgiving about!
Old Jan 9, 2007 | 07:24 AM
rc'S's Avatar
rc'S
Ok for us, gee I hate to us this word, newbee's, what is 'gummy fledge'?
Old Jan 9, 2007 | 07:52 AM
MiniMaybee's Avatar
MiniMaybee
Try this Gummi Pflege . About the best place to get it and the rest of the Einszett products.
Old Jan 9, 2007 | 11:32 AM
homerwest's Avatar
homerwest
Wow, I thought you guys had made up a left handed smoke shifter....
