Injectors Question
Old Dec 27, 2005 | 08:27 PM
Bradley99's Avatar
Bradley99
Injectors Question
This was posted on mini2. I copied it here in hopes of more elaboration on the subject:
If the stock injectors provide adequate F/A ratio then what is to be gained by putting in larger injectors? Seems the A/F ratio will be the same regardless of injector size.
If due to engine modification (more boost?) the stock injectors become inadequate, how will one know?
In the event that the injectors are inadequate does the ECU prevent a leaned out condition - say by throttling back with subsequent HP loss?
Finally, at what point with respect to engine modification will larger injectors become necessary?
Old Dec 27, 2005 | 08:49 PM
trackster's Avatar
trackster
duplicate post
Old Dec 27, 2005 | 08:52 PM
Electron_Mike's Avatar
Electron_Mike
Forgive me if I misquote something, but this is mostly from memory. As long as you're not pushing more air in, adding bigger injectors really gives no gain.
The stock injectors generally only become inadequate near redline, when they can't keep up with demand. This can result in detonation. As for other signs that they're inadequate, I'm not sure...
I think that the ECU does indeed retard timing, resulting in a HP loss, but I'm a little fuzzy on that.
Larger injectors are usually reccomended with at 19% pulley, but to add them, you need an upgraded ECU to recognize them. Otherwise, they'll dump too much fuel and the car will run way too rich. Everyone I've heard who's done the 19%/injectors/GIAC have praised it.
Old Dec 27, 2005 | 08:54 PM
trackster's Avatar
trackster
I can hopefully provide a bit of info with regards to the last part of the post. When most people get to a total of 19% over drive of the super charger they usually opt for larger injectors. They could be using a combination of pulleys wether it be a 17 + 2 or a 16 + 3 or just a straight 19 . A injector size in the 400 cc range is the prefered choice. Additionally those using NOS like to upgrade as well to give a larger margin of saftey in preventing a too lean condition. Hope this hels a bit.
John
Old Dec 27, 2005 | 08:58 PM
88m's Avatar
88m
most people know that they need more fuel when the get on a dyno, or have their own wide band o2.
Old Dec 29, 2005 | 07:34 PM
SpiderX's Avatar
SpiderX
I have had: stock, 380s, 400s and 440s..... I have had the best results with the 400s.....the 440s can be trimmed to work just fine but for circumstances beyond my control I went back to the 400s and they worked well with out a custom tune...later I tuned them
patsum
26
May 29, 2021 06:29 PM
donniedarko
Oct 21, 2015 01:15 PM
Manny_cooper
Sep 3, 2015 05:48 AM
