Suspension Mounting Koni FSDs
Old Dec 23, 2005 | 04:29 PM
Stevie B's Avatar
Stevie B
Mounting Koni FSDs
I just received my Koni FSDs (mail order). I need to get the mounting appointment setup and was curious as to what labor cost price range would be. I like going in armed with a reference point, not that I fear being ripped off. Also, will the car need an alignment or anything? Thanks!
Old Dec 23, 2005 | 10:45 PM
rkw's Avatar
rkw
You should figure it by hours of labor, at whatever the labor rate is where you are. When I had my FSDs installed, I had quotes from two shops for 3.5 hours and 4 hours. Alignment was ever mentioned to me. Rates in the SF Bay Area are roughly $75-100/hour. I think my MINI dealer charges $140/hour!
I love the FSDs. I wanted to improve the ride for my wife and child when they are in the car, but I didn't want to compromise handling. The ride improvement is immediately obvious, and I think the handling has also improved.
Old Dec 23, 2005 | 11:27 PM
xtremepsionic's Avatar
xtremepsionic
Thats about right. It took me about 6 hours to change the struts and shocks of my old Volvo without power tools and working alone.
The FSDs are awesome, possibly one of the rare mods where there are no down sides! (other than the cost)
Old Jan 2, 2006 | 06:53 AM
grosephd's Avatar
grosephd
Koni FSD's
Anybody installed the FSD's with the stock 05 MCS springs?
Old Jan 2, 2006 | 07:00 AM
erik99's Avatar
erik99
Per at Grassroots Motorsports (he frequents this board too) installed them on his MC with SS Plus (same as MCS?). Lurk on over there for his impressions.
Old Jan 2, 2006 | 07:22 AM
Stevie B's Avatar
Stevie B
Mine are going in with stock springs (05 MCS). I can't see a logical reason to install with lowering springs due to the average aftermarket spring lowers the car too much for the FSD to work as designed. Not worth the risk and lowering a MINI for street use is not necessary anyway. Just waiting on my H&R rear sway bar to arrive before the install. I should have it all mounted up by the middle of the month, weather permitting.
Old Jan 2, 2006 | 09:24 PM
FastBlackS's Avatar
FastBlackS
Koni FSDs
I had the FSDs installed on my '03 MCS three weeks ago, and I must say the ride has improved tremendously! The jarring that used to happen when driving over manhole covers, expansion joints and other road irregularities doesn't happen anymore, and its now a much more comfortable drive. As recommended by Koni, I stayed with the stock MCS springs. Not sure how the FSDs would work with aftermarket springs tho'...
Handling hasn't changed as compared to the standard MCS shocks, and may have improved- although I can't say for sure if this is true! Like Stevie B, I don't want to lower my car, but instead will be getting an 18mm H&R rear sway bar just to tighten up things a bit.
FWIW, Koni FSDs are OEM shocks on the Lamborghini Gallardo, so if they are good enough for the Lambo, they must be good enough for our humble MINIs!
Old Jan 3, 2006 | 03:16 AM
grosephd's Avatar
grosephd
FSD's vs. JCW shocks
Anybody have the opportunity to compare these two sets of shocks?
Old Jan 3, 2006 | 07:45 AM
kenchan's Avatar
kenchan
if i had the opportunity to drive such supercar, i could tell you...but it all sounds like an advertising campaign to me. jk
Old Jan 4, 2006 | 09:25 AM
ScuderiaMini's Avatar
ScuderiaMini
Ken, agreed
I would try the Koni FSDs with JCW springs, not a dramatic drop, should work perfect with the shocks.
Old Jan 4, 2006 | 10:05 AM
Stevie B's Avatar
Stevie B
Originally Posted by ScuderiaMini
Ken, agreed
What's the drop?
Old Jan 4, 2006 | 11:48 AM
meb's Avatar
meb
10mm
Old Jan 4, 2006 | 02:41 PM
Stevie B's Avatar
Stevie B
Originally Posted by meb
10mm
I'd agree that's safe to say it shouldn't interfere with the FSD operation. If free I'd take 'em. How much are they anyway?
Old Jan 4, 2006 | 04:30 PM
FastBlackS's Avatar
FastBlackS
I'd be interested in the JCW springs to complement the FSDs too! Assuming they work well together, both combined with a good 19mm (or even 18mm) rear sway bar would be the perfect set up that should have been standard on the MCS.
Filmy
15
Jun 6, 2023 06:27 AM
smdmini
Oct 7, 2019 06:05 AM
minimofo
Sep 30, 2015 12:26 AM
Mb460
Sep 14, 2015 05:50 AM
Sep 4, 2015 02:34 PM
