Help me decide on the intake.
I am going back and forth and can't seem to make up my mind, so how about some help. My two choices are:
MyMini Cooper filter:
or, K&N filter:
Does any one have any opinions before I let the wife buy me the Christmas present?
P.S. Rick, I know you can make me one for $90, but keep it to yourself...
or, K&N filter:
Heck it's christmas
Why sweat the details?
You'll be fine in any case.
Does color make any difference? Your MINI is LY.
Appearance is a criteria. Blue is nice and probably shows less dirt in the long run.
For the MC sometimes there can be rubbing of the inner bonnet so check for any fitment issues.
Increased power isn't really that much different between similar models of intakes, nor is intake loudness.
Don't forget the matching cat-back exhaust for your birthday (if you don't already have one).
or, K&N filter:
or, K&N filter:
What makes you say that?
The MyMINI One is just the same aFe filter that pops up on ebay once in a while. The S intake thay the aFe brand sells is probably the hokiest thing ive ever seen, and that cooper intake tops it!
You have to re-use your restrictive factory rubber intake tube and clamps.
The K&N is a nice smooth transition using a new tube.
My vote is also for the K&N.
My reason why is this: If I mod any part of my car, I want to do it right the first time. I don't want to skimp, and by a cheaper part, thinking that I could replace it later when I get more money, with a better part.
It might take you a bit longer to save up for the better parts, but you'll be happier with the finished product later.
That being said, I agree with the previous poster, that the K&N seems like it is higher quality. Not just because it is a name brand known the world-over, but because K&N has been proven to be the best, or equal to the best...
Lastly, I also like that it replaces the stock accordian-fold tubing, for smoother flow.
I bought the K&N and I couldn't be happier, the sound is great, seat of the pants throttle response is better. No Dyno numbers, but who cares, a dyno run would cost as much as the intake.
My guess is the My MINI intake won't fit the '05 correctly.
Steve
Steve
Thanks for the replys. The MyMini intake should fit the '05. At least, I was so assured by Pete at MyMini. Real nice guy by the way. That being said, Rick-Not-So-Red made very valid points which I didn't fully consider before. Another thing that was steering me towards K&N is the fact that they have incorporated wire managment into the kit. (I know it's just one small bracket, but I hate loose wires, or having to zip tie stuff where it doesn't belong.)
So of I go to place my order.
Neil
05 MCS - Stock intake/filter
96 M3 - ITG foam intake, one or two other mods
Originally Posted by NeilM
Progressive size layered foam filters such as ITG or Piper Cross maintain their flow better as they load up with dust than do oiled cotton types (K&N). Unless you're not bothered about the need for more frequent cleaning and re-oiling to maintain performance, I'd be looking for an intake that uses foam.
Neil
Neil
But you do bring up a good point. How often would you clean the K&N filter?
I agree with you and would like a foam filter. However, no one makes it for '05-06 Coopers. Hence, the pointed question about the two options available.
Steve
While I was looking for the intake, I did look at PiperCross. However, they never listed any of their intakes for regular Coopers as fitting the '05. And even more so, their web site still lists '05 Convertible as one of the cars they need to conduct testing on. That did not give me much confidence, so I looked somewhere else.
Maby there is some difference in hardtop and convertible?
Originally Posted by Maaij
But they never said it didnt fit a 05
Ah. For some reason I missed the fact that you were talking about the same intake...
Edit: I meant to post this in the other thread... forgive me, I'm hopped up on cold meds.
Originally Posted by gbuff1
ITG makes a foam panel filter to fit 05s..I have a brand new one and would like to sell it if you're interested.
Originally Posted by chrisneal
Has this been confirmed? I know their website says it will fit, but it also says it will fit '02-'04, so I'm skeptical. I haven't yet heard of anyone actually installing one.
Neil
05 MCS
96 M3
