Gas Pedal Stop Response In the middle of the Traffic
Old Dec 14, 2005 | 07:49 PM
hsienboy's Avatar
hsienboy
Hi all,
I have 05 MCS with 7,000 miles. As I was driving home today, my MCS jerk a bit and I lost all the power at the gas pedal in the middle of on going traffic. Luckly I was able to slide to the side of the road without getting hit . So when the car is stoped, the engine is still on and idling at 1ooo rpm, but a bit shaken, like it lost a spark-plug. I notice the EML and service engine light came on. I am planning to take the car to dealer for service first thing tomorrow because I dont want it to happen again. It could be a lot worse if it happen again. Anyone have similar experiences? and any suggestion of what happened?
PS. I was shifting from first to second gear, and my DSC is switched off.
thank you
hsienboy
Old Dec 14, 2005 | 10:24 PM
kenchan's Avatar
kenchan
another time to get a civic hybrid thread.
post us a scan of what your dealer provides.
Old Dec 15, 2005 | 07:17 AM
MadHatter's Avatar
MadHatter
I can only comment...
that the gas pedal itself has two independant magnetic 'hall sensors' to indicate what the pedal is doing. If the BC1 general computer reads differently from both sensors, then the car will not accelerate. Same type of logic on the brake pedal also, don't know how the clutch works, probably more mechanical.
Pedal was probably a means to an end in this situation and not related directly as direct linkage in an older car might.
Good luck, - help us all out by posting the mechanic solution when you get this figured out.
Happy Holidays
Old Dec 15, 2005 | 10:56 PM
hsienboy's Avatar
hsienboy
I call service dep. today and I will bring my car in monday, I will post the result. I was reading another thread about the false bypass valve and TB, my situation sounds a lot like that....
wil
Old Dec 23, 2005 | 11:20 PM
hsienboy's Avatar
hsienboy
Answer
all right guys, i finally got my mini back on wednesday. Dealer found fault code P1688, and it is a faulty electronic throttle monitoring devise. they said it is a recall item, so they replaced the part, and hold on to my car for extra day to road test.
and so far so good, im able to motoring like the way it is suppose to be.....
so happy to have my mini back
ps. they also check the intake system for any leak, and pressure sensors for incorrecct value.. and they found nothing........just want to added for someone who understand all those means.....
Old Dec 28, 2005 | 10:46 AM
qweewq12's Avatar
qweewq12
actually I had the same symptons on my MCS last night and this morning... took the car in today... still waiting on the results.
Old Dec 29, 2005 | 09:34 AM
LombardStreet's Avatar
LombardStreet
Moderator
Originally Posted by hsienboy
they said it is a recall item...
I have an '05 MCS. I haven't heard anything about a recall. Should I contact my SA?
Old Dec 31, 2005 | 06:16 PM
hsienboy's Avatar
hsienboy
YEAH, IF IT IS CAUSING U PROBLEMS....
WIL
eliseo1981
Sep 4, 2015 02:33 PM
wildwestrider
Sep 4, 2015 06:25 AM
Suspension Products
Sep 3, 2015 09:41 AM
Llanrhaeadr_Cymru
Country Roads MINIs
Sep 2, 2015 07:12 PM
broncobuddha
Sep 1, 2015 06:32 PM
