Minis And Cold Weather
Old Dec 7, 2005 | 06:56 PM
willy69's Avatar
willy69
today the temp in northern illinois was -9 deg f. my mini went about 6 miles and got the eml light and the car went into limp mode. shut the car off then restarted and all was fine untill i was almost home, same thing happened. has anyone seen this before? this car has a cai, pulley, exhaust, mth. any help would be great.
Old Dec 7, 2005 | 07:05 PM
Wagnbat's Avatar
Wagnbat
Don't know if it's related, but check:
https://www.northamericanmotoring.co...ad.php?t=43546
Old Dec 7, 2005 | 07:13 PM
kenchan's Avatar
kenchan
ive driven my car in the cold here in chi-town in the past with no issues.
the MTH might be doing something... not sure. can you revert back to your
factory program?
Old Dec 7, 2005 | 07:19 PM
willy69's Avatar
willy69
i will try the stock file this weekend, too cold to do anything. i have never had any issues with this car until this.
Old Dec 7, 2005 | 08:54 PM
kenchan's Avatar
kenchan
*****- is this the first winter with the MTH map?
honestly, this is one reason why I haven't taken the plunge yet on the MTH... when you
push your ECU maps to the limit, it usually turns into issues when you can't adjust
to winterized gas and also the super cold temps. you never know wat to expect.
wish TurboXS made Utecs for our cars... (had one on my WRX...it is by far the
best piggyback ive used...user programmable, has auto logging, etc...well, that's
a turbo car so totally different...but still, that autologging was a very useful tool
to diagnose).
Old Dec 8, 2005 | 03:49 AM
willy69's Avatar
willy69
yes, this is the first real cold weather the car has seen, it's a 2003 with 37,000 miles.
Old Dec 8, 2005 | 04:50 AM
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
Funny that this cane up. Yesterday when I pulled out of the driveway my mini ran a little rough. As I tried to accellerate down the road it became so rough that I literally could only inch forward. The CEL came on and it stalled. When I restarted, it ran perfectly. The CEL went out after the usual 3 cycles. Weird.
Old Dec 9, 2005 | 05:51 AM
1FSTMINI's Avatar
1FSTMINI
Theres a bulletin out for the by-pass valve sticking due to the cold weather. This will put the car in limp mode if the valve cant open. Dealer will replace valve and reprogram DME under warranty if you have any left.
TREX
Nov 2, 2019 07:31 PM
Dec 23, 2015 10:36 AM
minicoclub
Nov 11, 2015 07:25 AM
minicoclub
Aug 25, 2015 09:07 AM
ludedude
Aug 10, 2015 07:16 PM
