My mini shocks me when I get out
Old Dec 4, 2005 | 07:11 PM
The_R1_Kid's Avatar
The_R1_Kid
My car shocks the crap out of me every time I get out of it. It's really really annoying. It’s done it since I picked it up. Any ideas on how to cure this problem?
Old Dec 4, 2005 | 07:17 PM
rrdusek's Avatar
rrdusek
switch the carpet floormats to those cool rubber ones. worked for me
Old Dec 4, 2005 | 07:25 PM
Wagnbat's Avatar
Wagnbat
When I first read the post, I was thinking cloth seats... But yeah, carpet will do it too. Or wear insulated gloves when you get out.
Old Dec 4, 2005 | 08:41 PM
kenchan's Avatar
kenchan
hold the metal part of the door, then step out.
Old Dec 4, 2005 | 09:00 PM
FlynHawaiian's Avatar
FlynHawaiian
Wear a ballon on your head
Sorry couldn't resist. Rubber mats FTW
Old Dec 4, 2005 | 09:01 PM
cooldaddy's Avatar
cooldaddy
every day, every time
Old Dec 4, 2005 | 10:42 PM
modified mini's Avatar
modified mini
maybe your car is trying to tell you something.
Old Dec 4, 2005 | 10:46 PM
Mini2Go's Avatar
Mini2Go
Coordinator :: Pitt Stop MINI
I think every car I get out of shocks me - and not some little zip - it's always a big ZAP!!! To the point that it practically hurts!
I have rubber mats in two of our cars, carpet in the third. Leatherette in the MINI and cloth seats in the others. I'll have to start paying closer attention to when and how.
Old Dec 4, 2005 | 11:25 PM
MCuS's Avatar
MCuS
I have same problem!
I tried to be smart one time and use my knee to push the door handle to close the door I didn't get shocked.. but when I when to open my gate, my gate shock the crap outta me...lol.
But what KenChan said about holding the door handle before you get off your seat works just fine.
Old Dec 5, 2005 | 01:02 AM
Steeroidz's Avatar
Steeroidz
Touch the door with the back of your forearm first. Hurts a LOT less (in fact I find it doesn't hurt at all) than getting hit at the tip of your finger/fingernail. Just take the zap on a larger, bare portion of your body, will be a lot easier =)
I've had to get in the habit of doing that with my truck on the odd day it's really cold here (actually been a tad chilly here a lot lately).
Old Dec 5, 2005 | 02:20 AM
fred3's Avatar
fred3
Doesn't make any differenc...
I have the rubber mats and you still get shocked.
Old Dec 5, 2005 | 03:19 AM
Stu(pid)'s Avatar
Stu(pid)
Try not wearing any nylon / polyester clothing?
Old Dec 5, 2005 | 03:58 AM
MrT-Man's Avatar
MrT-Man
Try wearing different shoes. I used to always get shocked with a particular pair of running shoes, and the shocks stopped when I changed them.
Also a painless way I found of discharging myself is to hold one end of an all metal key (not like the Mini key that has plastic at one end) and touch the other end to whatever normally shocks you. You get a spark between the end of the key & the thing you touch, but no shock pain!
Old Dec 5, 2005 | 04:04 AM
Salt and Pepper's Avatar
Salt and Pepper
static guard
I've used Static Guard, usually in the evening when I'm done for the day I"ll spray some inside and shut the door because the fumes are a little rough on the nose if you stay in close quarters when you do it. Then the next day the shock is usually gone. You might try putting some dryer sheets in there too, but they don't seem to work as good as the Static Guard.
Old Dec 5, 2005 | 04:50 AM
mdsbrain's Avatar
mdsbrain
I have rubber mats and peeps complain they still get shocked. I see it happen to my passengers more then me.
I have the cloth/leather seats
Old Dec 5, 2005 | 05:10 AM
Byron's Avatar
Byron
Shocks when getting out
Wear a hat that should help,by covering most of your hair that transfers static electricity.
Old Dec 5, 2005 | 05:13 AM
nohbdy's Avatar
nohbdy
Yea, I get shocked all the time too, I wear sandals all the time, so I just touch my toe to the ground before I close the door... Kinda goofy, but oh well.
Old Dec 5, 2005 | 09:43 AM
PEP's Avatar
PEP
Coordinator ::Bluegrass Minis
Yup, same here. I have the cloth seats and the rubber mats. I hold onto the door sill when I get out.
Old Dec 5, 2005 | 10:03 AM
FlynHawaiian
It could be your mini is trying to tell you it wants to be driven more
Old Dec 5, 2005 | 10:09 AM
The Short Bus's Avatar
The Short Bus
I get shocked all the time. Pretty bad too. Rubber floor mats and cloth seats...
But i've gotten so used to it, i kinda like being shocked
Old Dec 5, 2005 | 10:20 AM
minibrokaw's Avatar
minibrokaw
I had huge shocks from my previous car (peugot 407) The only way I would close the door was with my arm, never my hand. My idea is that the static builds up while you are driving and as soon as you try to get out you get zapped on the hand. Just try closing the door with any part of your body that is clothed.
MINI in Greece
Old Dec 5, 2005 | 10:34 AM
kenchan's Avatar
kenchan
yep, this is the only option that works with consistency.
all the other suggestions are pretty funny though.
Old Dec 5, 2005 | 11:03 AM
Wagnbat's Avatar
Wagnbat
It's your clothing. Jacket, socks... Whatever you wear thats fluffy... As well as your dry weather conditions.
The zap is your body discharging the charge that built up from those items gently rubbing against you, under dry conditions.
The solution would be to somehow ground yourself. Such as getting a simple grounding strap from an electronic workbench (like $4 @ radioshack), and ground yourself to a metal part of the car... Maybe the shifter? Grounding straps usually have break-aways...
And while that may sound silly, the rubber mats only prevent you from generating static electricity from the Mini's carpet. If you have other fabrics generating it, the mat won't help, and any time you touch ground (pretty much any piece of metal) you'll get shocked.
I get shocked every day at work because we have metal door ***** which are isolated from the rest of the metal parts on the door. So I always touch that **** with the back of my hand, middle knuckle, before going out, because it doesn't bother me much getting shocked there.
And one last thing. Touching someone else may discharge it too... And probably make you feel better about the whole thing as well.
Old Dec 5, 2005 | 11:13 AM
kenchan's Avatar
kenchan
Old Dec 5, 2005 | 11:14 AM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
That's how Sparky got his name.
