Phantom of the Blower
I have a 2003 MCS that out of the blue started to turn its engine fan on while sitting in the garage with the ignition off. Initally this lasted about 5 min. and then stopped as suddenly as it started. Then the other day I got up in the morning and the battery was dead. When I attached the jumpers the fan started up. The cover of the relay box under the hood indicates two relays for the engine fans (I & II). when I removed the relay I nothing happened but when I removed relay II the fan turned off. I have not reinstalled the relay and the problem has not returned. Could this be as simple as a bad relay (easy fix) or is the problem deeper in the electricals (bad news)? Any insight would be appreciated.
Mike
Mike
Drivetrain Is the Phantom Grip LSD for real??
minihune
Jun 3, 2005 07:58 PM
