Drivetrain Dinan Exhaust for cooper S
Hello everyone!
I am new to the group. I have a 2005 cooper S with the aero package, performance pulley, cowl induction intake and stage 3 software. I am considering the Dinan performance exhaust system to allow the engine more breathing room. Do any of you have this exhaust and how well does it work and sound? I have an hour drive to and from work every day and LOVE my mini! :smile: :smile:
Dinan Exhaust
I have an 03 cooper S with Dinan stage 3 software. cowl induction and exhaust....the exhaust is great sounding. Not too loud but much more better than stock. Throaty with a gurgle/popping when you let off the throttle....Having a big problem with Dinan making compatible software for the update revision Mini installed last spring..they've been working on it since then...Now they tell me it may be a couple of more months. It seems it affects about 2 or 3 dozen mini owners. So since the update I'm back to oem specs fot the CPU...Probably 12 HP less than the stage 3....I'm bummed out.
Dinan Exhaust
I have the Dinan exhaust, along with intake and ecu, and find it a great combination; robust when on the throttle and similar to stock while cruising. The only issue I have is that the exhaust seems loose. Having dealer check the mount but I've heard it is a common concern; have not heard of any coming off.
Reason for stage 3 software
The way I understand it from Dinan, the cowl induction and pulley upgrade pull more air into the engine creating more exhaust. The stage 3 software changes the timing, combustion, etc to get maximum effect for performance. I have found that after these mods, my "S" was actually scary in the power band in all six gears, i.e. 0-80 mph on expressway entrance ramp and still just loafing along! Next I want to do a larger intercooler and an after market throttle body (not Dinan) that's twice the size of the stock one.
Jan 4, 2019 12:51 PM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 02:03 PM
