Navigation & Audio Nav OS: change the written text language (not the voices)
Hi guys,
I've already read the post that talk about how to change the voices in Bmw Nav OS and here I would like to discuss how to change the language of the written text that is shown at the navigator display.
I'm using the OS v24 and I've found in it a directory called "LANGUAGES->0200" that contains some files like "GB_M", "USA_M", "E_M", "I_M" and a file named "Language.list.
I've open them and I've found that they contains also the sentences that are shown by the Nav display. I THINK (that is, I'm NOT SURE) that it should be possible to change the language of written text just renaming these files. For example, if your navigator OS shows only GB,USA,E language and you want that the written text will be in french, you should only rename "E_M" to "E_M.bak" and "F_M" to "E_M". In this way you should get the written text in french: remember that when you choose the language in your display you still will see "E" as Spanish but the language will be set to French.
I know that it can seems not so clear but it is the same procedure that has been explain to change the voices.
I would like to know if someone knows if this is the right procedure to change the language of written text or if this is wrong!!!
Help me,
Denis
Help me,
Denis
Navigation & Audio I need help with the Nav!
OYWHATNEXT
Navigation and Audio
12
Jun 14, 2016 09:36 AM
kevinminict
Jun 3, 2016 01:31 PM
