Suspension Does Bilstein SP settle over time?
Old Nov 8, 2005 | 11:33 AM
andrew_py_ng's Avatar
andrew_py_ng
Hi,
Thanks for the help of NAM members I finally installed upgraded from Eibach/stock shocks to Eibach/Bilstein SP. The ride is sweet!!! In fact it is so comfortable, all the harshness with the stock shocks were gone. Body movement is much more controlled, no excessive diving or bouncing. It is a great setup.
However I do notice that my car is sitting slightly higher than before, probably about half an inch higher. Anyone know if the ride height will settle over time? Also will the ride gets stiffer after the shocks has broken-in?
Also, interesting the ride height is very susceptable to elevation change. What I mean is, if the road is *slightly* sloped to the left, I have measured that the rear-right wheel gap is 10mm more than my rear-left. However, there is no difference if the slope is even. Could anyone explain that??
Andrew
Old Nov 8, 2005 | 11:47 AM
JeffS's Avatar
JeffS
Sounds like the perch height is slightly different on the new shocks.
No, shocks don't settle. The springs are what's determining the ride height.
Old Nov 8, 2005 | 03:42 PM
satay-ayam's Avatar
satay-ayam
Bilsteins use a high pressure gas charge and a mono-tube with a large piston on which that charge effectively acts, which can increase ride height relative to other shocks (especially blown out old ones ).
Old Nov 8, 2005 | 07:08 PM
m332is's Avatar
m332is
As I noted in a diff thread, I added the H&R springs and Bilstein shocks. My drop is not as much 1.5" as other have gotten with the H&R sand stock shocks . I think I dropped by approx 1 inch. So I think I confirming your 1/2 diff.
BTW, I am happy with my ride, drop and overall look.
Vince
Old Nov 9, 2005 | 10:45 AM
Minirowski's Avatar
Minirowski
Originally Posted by andrew_py_ng
Hi,
Andrew
Could you post the part number for the blisteins?
Can I use any lowering spring with blisteins?
Old Nov 10, 2005 | 03:40 PM
andrew_py_ng
They are
VE3-A324-H0 [size=-2](FRONT RIGHT)[/size]
VE3-A323-H0 [size=-2](FRONT LEFT)[/size]
BE3-A325-H0 [size=-2](REAR RIGHT&LEFT)[/size]
Old Nov 13, 2005 | 10:29 PM
groove67's Avatar
groove67
You should not see any drop in the Steins. I have had them on my 69 Camaro for 3 yrs and even did an engine swap and new wheels/tires and the car actually sat about a .5" higher than before. I do have after market springs. I know that the VW guys have no problem with the steins either.
Allen
Old Nov 14, 2005 | 03:11 AM
andrew_py_ng
Thanks guys. I don't mind trading off ride height for the awesome Bilstein ride. :smile:
Old Nov 14, 2005 | 07:05 AM
m332is's Avatar
m332is
Check out my gallery if you want to see pics with the H&R/Bilstein combo.
Cereall
Sep 5, 2019 06:05 PM
bjcarter2
Aug 31, 2015 04:03 PM
sabjcw
Aug 14, 2015 07:40 AM
minipopkart
Aug 13, 2015 05:22 AM
robyb
Aug 8, 2015 06:04 PM
