Suspension Koni yellows...
Old Oct 26, 2005 | 11:59 PM
codemunkee's Avatar
codemunkee
Koni yellows...
For those that have the Koni yellows, at the full soft setting is the ride comparable to stock? I'm about to buy a set to be combined with koni's progressive springs and want minimal complaints from the wife while still lowering the car "the right way" (shocks and springs). Hope that makes sense.
Old Oct 27, 2005 | 10:15 AM
kenchan's Avatar
kenchan
i must have lowered my car the wrong way.
Old Oct 27, 2005 | 10:38 AM
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
If you have a relatively new Mini, I'd stick with the stock struts/shocks. They're more than adequate for street driving and nowhere nearly as stiff as the Koni's.
Old Oct 27, 2005 | 10:51 AM
kyriian's Avatar
kyriian
id try koni's new FSD if you are worried about ride complaiancy
Old Oct 27, 2005 | 10:56 AM
MSFITOY's Avatar
MSFITOY
I don't know that but it would sure give you a bouncy ride like those Ricers with chopped springs The Konis would be set too soft to control the heavier spring rates...
Old Oct 27, 2005 | 10:59 AM
vader's Avatar
vader
I have yellows and H-Sport springs. They are stiff no matter where they are set. I would agree about getting FSDs if you are worried about ride quality
Old Oct 27, 2005 | 12:20 PM
JeffS's Avatar
JeffS
Yellows are uncomfortable to some because of the relatively firm compression damping.
Unlike many other single-adjustable shocks, the adjustment **** on the Yellows only controls rebound damping, changing the setting to soft isn't going to do anything for comfort. My personal feeling is that there's a "right" setting for a spring rate and trying to constantly adjust the shock for ride quality is pointless.
I've heard really good things about the FSD (gold) shocks from someone who works at Koni. He said they did wonders for ride quality AND handling. At the same time though, he said I shouldn't buy them with my current springs (H&R). If you're so low that you're hitting the bump stops the shocks won't work right.
Old Oct 27, 2005 | 12:23 PM
codemunkee's Avatar
codemunkee
sounds like im not getting the yellows then. bummer, cause i found a really good deal them.
Old Oct 27, 2005 | 01:09 PM
kenchan's Avatar
kenchan
Just lower it the wrong way and you're set.
Old Oct 27, 2005 | 01:13 PM
MSFITOY's Avatar
MSFITOY
How can you know if she'll complain if haven't even tried this yet? Is this your Mini or hers?
Old Oct 27, 2005 | 04:32 PM
codemunkee's Avatar
codemunkee
i bought them after talking with the vendor so we'll see how it goes. my wife drives an MR2 spyder so her car is much stiffer than mine and i was kind of let down by the MINI handling. i had a 2003 MINI with KWs previously (I now have a 2004 w/ the softer suspsension) and it handled decently. i know it's apples and oranges but the MINI feels like a sloppy pig compared to the MR2 so I'm hoping to get the go kart feeling back w/o my breaking my back on every road imperfection. just to add more to the equation i tossed out the 17s w/ runflats in favor of some 16s w/ non run flats. hopefully that will help even out things a little bit as well.
the reason im concerned about it having a compliant daily driver feel is that my wife and i agreed this would be the family car (as the mr2 is certainly not well suited for the task). sick family huh?
RobbyD
Jan 29, 2019 01:22 PM
sssevita
Mar 20, 2016 06:24 AM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
Emnotek
Sep 29, 2015 07:37 AM
