Interior/Exterior Side Grille Removal - WHAT A PAIN!
Old Feb 4, 2003 | 02:45 PM
Albert's Avatar
Albert
Is it me or is it a lot harder to remove the side grilles than other people have suggested?
I was successful in removing mine last night, but not without the expense of my hands (particularly my index fingers are now swollen to the point that I can't bend em). It took forever to push it from the inside out (e.g. cramped engine bay).
Anyway, just wondering if I went about it the wrong way?
PS - In addition to pushing from the engine bay outward, I also removed the side repeater lenses for leverage.
Old Feb 4, 2003 | 06:10 PM
GBMINI's Avatar
GBMINI
You are talking about the tiny vent grille where the repeater light is? I switched it for chrome last summer ... took me only seconds I think! Maybe your MINI didn't want to lose it ...
Old Feb 4, 2003 | 06:41 PM
JackmanAVP's Avatar
JackmanAVP
Albert, I read your post with fright as I just ordered the chrome side panels. When ordered, the salesrep said it would take minutes. I'm very mechanically inclined but a bit paranoid with screwing up a new auto.....I'll let you know how it works out...
Old Feb 4, 2003 | 08:30 PM
Albert's Avatar
Albert
Iancull, yes that's the part.
Jackman, good luck and let me know how it goes.
The problem for me was the fact that the rubber grommet that holds the forward part of the grille didn't want to let go.
Old Feb 9, 2003 | 01:09 AM
retroom's Avatar
retroom
Mine was very easy to remove. I just pushed the front part of the vent out away from the fender. It pops out maybe 1/2 inch. Then slide it forward to remove the back away from the fender. Maybe yours was glued in??? The process really is quite easy.
The rubber grommet should remain in the fender and only the plastic grill comes out.
retroom
Old Feb 9, 2003 | 02:38 PM
Albert's Avatar
Albert
You know, you may be right. When I finally got them off, I noticed a little bit of epoxy-like resin left over on the plastic posts.
Old Feb 10, 2003 | 05:09 PM
retroom's Avatar
retroom
When you reinstall the vent if it doesn't lock into place try pushing out on the inside of the black post as you are pushing the vent in. One vent wouldn't "lock" into the plastic post until I did that. I didn't have any problems with the other side..
retroom
Old Feb 13, 2003 | 08:41 AM
rataha's Avatar
rataha
I had 1 come out on the Interstate. They are ordering a new one. kind of a design flaw if you ask me. They should slide in at the front and pop in at the back instead the way they are designed the wind can catch them and flop them right out of the car. I am sure excessive speed had nothing to do with it
Old Feb 13, 2003 | 11:47 PM
Albert's Avatar
Albert
Thanks for the tip retroom. :smile: I get my painted grilles back tomorrow!!
boostedhaze
Jan 2, 2018 07:26 PM
ltjpunk7
Sep 6, 2015 07:32 AM
cm.d
Aug 19, 2015 08:51 AM
minipopkart
Aug 13, 2015 05:22 AM
