Interior/Exterior Anyone use the epod?
Old Oct 21, 2005 | 05:33 AM
mellow's Avatar
mellow
I think I'm going to go with the Defi BF Imperial gauges. However I'm not quite sure how they will be installed on the column. I came across the ePod and was wondering if anyone has used this in their Mini..
http://www.egauges.com/vdo_acce.asp?..._Cooper&Cart=1
Old Oct 22, 2005 | 08:39 AM
mellow's Avatar
mellow
No one has used the ePod for their gauges? I wanted to get input on this pod before I went with the Alta.
Old Oct 22, 2005 | 09:01 AM
FastBandit's Avatar
FastBandit
I use the ePod for my gauges and love it. It is clean and fully adjustable unlike the Alta.
Old Oct 22, 2005 | 09:11 AM
mellow's Avatar
mellow
Thanks FastBandit...I did like the fact that they were adjustable. Are those Delfi gauges? Can't quite make the name out on the dial. I'm looking at the BF Imperials.
Old Oct 22, 2005 | 09:15 AM
Dweezil's Avatar
Dweezil
FWIW, I don't think you can go wrong with the DEFI gauges. Are you considering the defi-link setup? I was this -> <- close to using the link setup in my supra, but just couldn't scrape up the cash at the time I was ready to buy gauges.
Old Oct 22, 2005 | 09:45 AM
mellow's Avatar
mellow
Dweezil,
Definately looking at the link setup. Going with the boost but not sure what the other gauge will be.
Old Oct 24, 2005 | 03:45 PM
FastBandit's Avatar
FastBandit
I went with the link setup for the fact that you can control the gauge's playback throught he controller. As far as adding up to seven gauges...I don't think there is enough room in the Mini for seven gauges! If you are gonna stay with only the two gauges, then it isn't a big deal if you get the Link System or not. Hope this helps on your quest for gauges.
StoopidGirl
Sep 19, 2006 10:39 AM
