Suspension Raising a lowered MCS.
Old Oct 13, 2005 | 04:08 PM
JCWr53's Avatar
JCWr53
Does anyone know if there are any spring pads or spring perch spacers for an '05 MCS? I installed lowering springs but I'm now scraping speed bumps much more than I'd like. Any ways of raising the ride height .3 to .5 inches, short of going to coilovers or going back to the stock springs? Thanks!
Old Oct 14, 2005 | 11:03 AM
kenchan's Avatar
kenchan
which springs are you using?
are you riding your bumpstops? did you cut the factory bumpstops
or use smaller bumpstops when you did the install? if not, you can just
cut the factory ones by about 1" and will give you the extra stroke you
need.
if you're scraping the bottom of the car, you can try different springs,
or i would recommend getting stiffer shocks/struts to slow down the
stroke.
im running H-sports on stock dampers and i rarely scrape bottom.
H-sports also come with new bumpstops so i rarely hit the bumpstops
either.
Old Oct 14, 2005 | 12:40 PM
Rick-Anderson's Avatar
Rick-Anderson
I just ordered these spacers from Mini Mania. I like the ride quality of the lowering springs I have but they make it about 1/2" too low. These should work.
http://new.minimania.com/web/Item/NM.../InvDetail.cfm
Old Oct 14, 2005 | 02:02 PM
kenchan's Avatar
kenchan
looks like you can almost use some exhaust gaskets.
Old Oct 14, 2005 | 02:35 PM
TonyB's Avatar
TonyB
another option...
If you just want to go up that minimally, consider a tire change as well. Personally, I dropped just a tad over .5" when I went with smaller tires...
Old Oct 18, 2005 | 08:58 AM
JCWr53's Avatar
JCWr53
Thanks, everyone!
nt
papawhiskey
Sep 14, 2015 05:47 PM
tag1260
Sep 14, 2015 11:30 AM
tag1260
Sep 11, 2015 07:12 AM
