Check that FasTrak bill! Error could cause a car to be charged big-rig truck rates
Old Oct 11, 2005 | 10:15 AM
eVal's Avatar
eVal
http://sfgate.com/cgi-bin/article.cg...11/FASTRAK.TMP
Hundreds of automobile drivers who used FasTrak to pay tolls on Bay Area bridges in the past year were electronically mistaken as being behind the wheel of a big rig -- and charged hefty truck tolls.
Officials at the Bay Area Toll Authority, which oversees FasTrak, acknowledged that electronic toll collectors on at least some of the eight local bridges have suffered breakdowns causing car drivers to be charged $12.50 -- the cost for a seven-axle tractor trailer to cross a span -- instead of the usual $3.
The problem appears to stem from a basic failure of maintenance. Laser beams that are supposed to read vehicles as they pass through toll booths can become coated with road grime or smeared by rain, and become blinded. If they aren't cleaned, the whole system can go haywire.
"We've had the problem intermittently and we've had the problem on different bridges,'' said Randy Rentschler, spokesman for the Metropolitan Transportation Commission, the Bay Area's regional transportation planning and financing agency. "Is it widespread? No. But when it happens, it affects a lot of people.''
Exactly how many people have been overcharged isn't known, and probably never will be. FasTrak users first have to spot the incorrect charges on their monthly statements and then challenge them.
In the past year, 500 to 600 such challenges were filed, said Rod McMillan, director of bridge operations and oversight for the Bay Area Toll Authority, which is a branch of the transportation commission.
"But not everyone disputes the charges,'' McMillan said. "Some people may not even notice the charges on their bills.''
McMillan said the number of overcharges isn't that high, considering that the FasTrak system collects 3 million tolls a month in the Bay Area.
"It does happen,'' he said, "but it's not that prevalent.''
Tolls on Bay Area bridges are assessed based on the number axles on a vehicle. Passenger cars and pickup trucks, which have two axles, pay $3. Trucks pay more, depending on size, ranging up to $12.50 for a seven-axle big rig.
FasTrak can overcharge a car driver if a toll booth's light curtain -- a device with dozens of laser beams that extend horizontally across a lane -- stops working.
The light curtain is part of the amalgamation of electronic gadgetry that calculates and charges tolls. When everything is going right, sensors at the toll booth detect an approaching vehicle, and overhead antennas read the FasTrak transponder and identify the associated toll account.
Then the vehicle passes through the light curtain, breaking the laser beams and indicating that it has entered the system. A treadle -- a device embedded in the pavement -- counts the number of pairs of wheels that cross it and calculates the number of axles. It stops counting when the light curtain is no longer broken, signaling that the vehicle has exited. The system calculates the toll to be deducted from the prepaid account linked to the transponder.
When the light curtain fails, the system depends solely on the treadle to determine the toll. That means it can automatically count axles until it hits the maximum of seven -- and signals the system to charge $12.50 to the transponder in the vehicle that triggered the counting. Then it starts over with the next pair of wheels that cross its threshold.
Since they're being mistaken as part of a truck, vehicles following the overcharged car could end up getting free rides.
Based on disputed charges, McMillan said, FasTrak had intermittent light-curtain troubles in May on the Bay Bridge, in February on the Dumbarton Bridge and in December on the Carquinez and Benicia-Martinez bridges. It appears that those failures varied from a fraction of an hour to a day and a half, he said.
Light curtains are a common component of electronic toll collections systems around the country. Peter Samuel, who operates Toll Road News, a Web site about toll collection, said the devices require fastidious and frequent maintenance.
"Light curtains are kind of tricky things,'' he said. "They need to be cleaned regularly. The main problem, as I understand it, is that grime gets on it. You have to be like a fussy housewife, to use an old term. You have to get out there and wipe it off.''
Toll authority officials believe the Bay Area breakdowns were the result of poor or infrequent maintenance. Rentschler declined to discuss exactly who might be at fault, however.
He said MFS Technologies, a WorldCom subsidiary that installed the electronic toll collection system, was responsible for maintenance as part of the warranty until about a year ago. Caltrans then took over until this year, when oversight of the FasTrak system was gradually shifted to the toll authority.
Last month, the toll authority hired ACS, the company that has been running FasTrak customer service since June, to handle maintenance. The company, whose contract includes rewards for high-accuracy performance by the toll collection system, is installing monitoring devices that will alert technicians when vital equipment such as the light curtains, treadles or transponder readers go on the fritz.
"Those two things should fix the problem,'' McMillan said.
FasTrak made its Bay Area debut in August 1997 on the Carquinez Bridge, seven years after it was promised to motorists. It took another three years before Caltrans finally got the system operating properly and expanded to the rest of the state's toll bridges.
The Golden Gate Bridge, which is owned and operated by an independent district, started work on its own FasTrak system in 1998 and opened it to drivers four months before Caltrans. In 2001, all lanes on all state toll bridges were outfitted to allow FasTrak use.
Despite efforts to increase the number of drivers paying tolls electronically, usage lags around 39 percent compared with 65 percent to 70 percent at bridges and toll roads on the East Coast.
As for motorists who believe their Mini Cooper may have been mistaken for a Mack truck, they can call the FasTrak customer service center at (877) 229-8655 to have their accounts corrected.
"We're taking care of everyone who was incorrectly charged,'' Rentschler said. "We're on top of it.''
Old Oct 11, 2005 | 10:32 AM
SRTech's Avatar
SRTech
I just checked, no overcharges for me. I use the GGB and Richmond bridge most of the time. :smile:
Steve
Wohnson89
Jun 10, 2020 04:53 AM
mdorn98
Aug 11, 2015 08:49 AM
xpunisherx
Aug 10, 2015 10:50 PM
ludedude
Aug 10, 2015 07:16 PM
kwijmbo
Aug 5, 2015 09:00 PM
