Drivetrain New Exhaust = annoying yellow light?
Old Oct 10, 2005 | 03:10 PM
toolmichael's Avatar
toolmichael
New 05 mcs in june had performance work done by bay bridge motors (entirely happy with their shop) that included an ultrik header amongst other stuff.
I added a miltek exhaust in august and immediately started seeing
that DAM**D yellow light, comes and goes, mostly stays. The code is
P 0420 "catalyst system efficiency below threshold (bank 1)".
Not too surprising with a free flowing exhaust (cat is hot?). Is this the "nature of the beast" and now must live with the light? change back to stock header for every emmision test. wonder if the code has changed. etc,
Mike
Old Oct 10, 2005 | 03:30 PM
chows4us's Avatar
chows4us
See https://www.northamericanmotoring.co...ighlight=P0420
Do a search and you will find lots of references to this problem
Old Oct 11, 2005 | 08:43 AM
toolmichael
Chow4us,
thanks for the reply....should have done a search, my bad.
Minimania supplied the header to bbm, just went on tilt when Jacque told
me it was "the nature of the beast".
Minimania is sending another Ultrk header with an improved cat under warranty. Wow, great service.
From what I understand R & R the header should be fairly simple.
Old Oct 11, 2005 | 12:09 PM
chows4us's Avatar
chows4us
Glad it worked out.
From reading, it appears the cats supplied by some vendors go bad quickly.
Old Oct 11, 2005 | 12:48 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
I'd look into replacing that cat with one like this:
http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
jlm has one on his MCS with no codes, and I used the same for years on my VW GTI 1.8T without problems. Some manufacturers are using cats that are woefully inadequate at doing what cats do.
Old Oct 11, 2005 | 04:31 PM
toolmichael
Thanks for the link Andy,
Minimania is sending the Ultrik with an "improved" cat, I want to give it a shot since it is a warranty replacement. I'll post if it fails and pay the $150 plus for your suggested replacement.
Mike
sevin
May 2, 2026 06:11 AM
mini yellow-haa!
Aug 13, 2015 11:18 AM
jrezzo
Aug 9, 2015 10:32 PM
