Team Dynamics Pro Race 1
Old Oct 4, 2005 | 01:23 PM
rwalkerphl's Avatar
rwalkerphl
I think I will be going with the Team Dynamics Pro Race 1 in 17 x 7, and was wondering what tire sizes to go for? I have H Sport Springs on my 2004 MCS, so, should I go for 205/45/17 or 215/40/17? Obviously, I want to avoid any rubbing.
Thanks!
Robin.
Old Oct 4, 2005 | 02:12 PM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
I have the 205/40/17 w/ stock spings. I have no tire rubbing issue. But the lower sidewall has dropped my car about .75" +/– an eighth. Just something to keep in mind
Old Oct 5, 2005 | 05:05 AM
Alex@tirerack's Avatar
Alex@tirerack
205/40 is a tad short. 215/40 is the shortest I'd go - with 36 psi behind it.
Alex
Old Oct 5, 2005 | 06:33 AM
rwalkerphl's Avatar
rwalkerphl
Hi Alex,
Someone mentioned to me 215/45/17 last night. Is that a more viable option?
Thanks,
Robin.
Old Oct 5, 2005 | 07:55 AM
JeffS's Avatar
JeffS
Alex
Only if you care about staying with the stock diameter. Some people would consider a smaller diameter a good thing - myself being one of them.
From a rubbing standpoint, a 205 is less likely to rub than a 215. A 40 profile is less likely to rub than a 45 (given the same suspension settings).
You should be fine regardless though.
Old Oct 5, 2005 | 08:34 AM
onasled's Avatar
onasled
To get the best handling out of a the tire, I would not go wider then a 205 on a 7" rim . 40 will ride quite a bit firmer then 45. Both options, 205-40, 215-45 should not rub at stock height. Always a possibility that a 215 will rub when lowered.
I'd stay away from team dynamics myself as they are impossible to communicate with.
patsum
26
May 29, 2021 06:29 PM
RDSJCW
Sep 16, 2015 03:54 PM
MidnightF56
Sep 10, 2015 01:04 PM
Tires, Wheels & Brakes
Sep 10, 2015 12:27 PM
Sep 10, 2015 10:52 AM
