from runflats to running flat on its face!! help
Old Oct 4, 2005 | 09:11 AM
piston's Avatar
piston
i just got 205/50/16 from tire rack.com... (yoko avs es100)
the car seems to have body roll that it didnt before. I assume it is the sidewall folding.. any input or anything that can help? more psi in the tire? anything! help !!
Old Oct 4, 2005 | 10:09 AM
kenchan's Avatar
kenchan
that's called grip!
Old Oct 4, 2005 | 10:17 AM
The MINITOR's Avatar
The MINITOR
I had the same question when I went from the 16" runflats to 18's. I got some answers, here's the thread I think: https://www.northamericanmotoring.co...ad.php?t=49544
Old Oct 4, 2005 | 12:05 PM
piston's Avatar
piston
thank you! i do hope it only is a rear swaybar....
some one said somthing about the tire load.. where can i find out what my tire load is when looking at my tire?
Old Oct 5, 2005 | 05:04 AM
Alex@tirerack's Avatar
Alex@tirerack
Whats your cold air pressures?
Alex
Old Oct 5, 2005 | 09:26 AM
piston's Avatar
piston
34 fronts 32 rears.
I viewed the other forum (drivetrain) and it seems this problem can be corrected with a rear sway bar. personally i think it is the tire rolling over (weak side wall) under heavy cornering..
but, then again, what do I know
Old Oct 5, 2005 | 10:19 AM
coopercrazy's Avatar
coopercrazy
Alex, what size tires are you running on your Kosei's(what size rims too), and are you lowered?
What do you do about not having runflats?
And what tire pressure are you running?
Old Oct 5, 2005 | 12:08 PM
VoiD's Avatar
VoiD
yeah it's probably the sidewalls rolling over. the runflats have a incredibly stiff sidewall.. try more air in the tires.
Old Oct 10, 2005 | 08:49 AM
brgmaxmini's Avatar
brgmaxmini
I switched from the stock run-flats w/ 16" v-spokes to SSR 16x7.5" rims and 205/50/16 Goodyear F1 tires, and the difference was fantastic. Ride quality of the car has improved dramatically for me, and I notice no performance issues, if anything it is only better. I am running 36 psi front and rear at the moment.
khumpert
Nov 30, 2015 11:48 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
ltjpunk7
Sep 6, 2015 07:32 AM
TJANK
Aug 24, 2015 06:11 PM
jziran
Aug 24, 2015 04:50 PM
