Need help! Will 18" Union Jack with 225/40 rub?
Old Sep 13, 2005 | 10:17 PM
si_power's Avatar
si_power
i'm driving a mini one and have those sets of wheels and tires sitting in the garage. My question is whether i can install those H&R lowering springs 30 mm and would it cause any rubbing in the rear?
Old Sep 13, 2005 | 11:20 PM
iguigu's Avatar
iguigu
If you lower it, it will rub. I had Hartge Classic with 225/40-18 before and it rub in the back. I swith the tires to 215 /35-18 much better........
Old Sep 13, 2005 | 11:48 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
For 17" and 18" wheels, tires that are 225mm or more tend to rub in the rear.
225/40-18 is quite wide (8.3+" tread width) AND tall. 25.1" outer tire diameter which is larger than stock. If you lower your MINI you would not be able to get enough clearance for the wider and taller tire.
215/35-18 measures about 7.6" tread width, 24" outer tire diameter and weighs about 3 pounds less than the 225/40-18 sized tire. It also fits a 18x7" rim better.
The stock MINI 17" tire has a 7.6" tread width and 24.3" outer tire diameter.
Old Sep 14, 2005 | 10:04 AM
si_power's Avatar
si_power
iguigu, does it always rub or once in a while. did u like the ride?
minihune, thank you so much for the information. So would the H-sport springs, which lowers the car less than H&R does, rub as well?
Old Sep 14, 2005 | 11:03 AM
iguigu's Avatar
iguigu
With no one sit in da back...is ok....
One time I had 2 people in da back, it rub CRAZY.
SO if you still going to use 225/40-18 then "cut" the plasic.
Old Sep 14, 2005 | 11:38 AM
ScuderiaMini's Avatar
ScuderiaMini
that is what I thought, I think you shold go with 225/35/18s.
Old Sep 14, 2005 | 05:39 PM
si_power's Avatar
si_power
the problem is that i already bought the 225/40
Old Sep 14, 2005 | 05:44 PM
si_power's Avatar
si_power
I had an idea of having the H&R lowering springs for the front and the OEM cooper S replaced on the back. Is it weird to have such an idea? Would it look strange?
Old Sep 14, 2005 | 06:28 PM
iguigu's Avatar
iguigu
Is really no big deal...wut ever is rubbing, jsut plasic...
Old Sep 14, 2005 | 08:04 PM
minihune's Avatar
minihune
Since you already have the tires in 225/40-18 you can just trim the plastic inner wheel wells.
First drive the car around a bit to get some rubbing -this will help to mark the areas needed to be trimmed.
Look at the How to trim link.
Get something to cut the plastic- dremmel is ok or heavy clippers since it is just plastic.
The more you lower your MINI the more you'd need to trim. I'd say go for the look you want and lower away, then trim as much as is needed to do the job and minimize rubbing.
H&R gives a lower drop, H-sports about 1" front and rear.
Old Sep 15, 2005 | 08:14 AM
buzzy's Avatar
buzzy
Is it posible to get those Hartge Union Jack's in the states? Anyone know how much they cost?
Old Sep 15, 2005 | 08:45 PM
si_power's Avatar
si_power
i had them fitted yesterday, didn't really like them. 18" aren't my cup of tea, right now looking to replace those with SE37 17"
Doc Pain
Mar 10, 2021 04:50 AM
freeman727
Dec 10, 2017 04:00 AM
OutMotoring
Mar 3, 2017 06:29 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
Moya45
Oct 17, 2015 07:54 AM
