Problem Fitting Wheels
Old Sep 6, 2005 | 12:41 PM
Red05MCS's Avatar
Red05MCS
I have been trying to mount my Sendel S70 wheels for auto-x. They are 15x6, 4x100 with a 40 offset. Problem seems to be that the holes for the lugnuts are too narrow for the flared end of the bolt to go in far enough for the bolt to grab the hole in the hub.
What should I do?
Old Sep 6, 2005 | 01:08 PM
keen's Avatar
keen
There are generally two sorts of lug bolt seats. one is sort of a acorn-shaped curve, the other is a cone. I forget which the MINI uses.
So first thing you need to do is make sure you're using bolts with the right type of seat. Sounds like you might need cones (acorns don't seat well in a cone hole, as you might expect.)
There are also a variety of lengths available. If you're not getting enough threads into the hub, get longer bolts. Most autoparts stores carry a selection of bolts in both chrome and black.
Stick an OE bolt in an OE wheel and see how much thread sticks out the back. Now take your new wheel to the store and find a bolt to give you a similar amount of thread sticking out, with a seat that matches your wheel.
Sometimes you'll find bolts in blister packs on the shelf, but you'll also find them in the bolt-bin behind the counter...so you may need to ask.
...david
Old Sep 6, 2005 | 05:14 PM
Passat774's Avatar
Passat774
There are two types of lug nut seats. The Mini Cooper uses a conical seat on the factory wheels and most aftermarket.
The other choice is ball seat. That is used a lot on Mercedes Benz in there OE applications.
If the wheels are ball seat you will need a ball seat lug bolt 12x1.5 thread pitch. Which is not very common.
What would be best is a super close up picture so we can try and see the seat of the wheel.. Or to see where the lug nut is getting stuck..
Old Sep 6, 2005 | 07:28 PM
bodinski's Avatar
bodinski
Sounds like you need a set of "tuner" lugs.
Old Sep 6, 2005 | 07:39 PM
Red05MCS's Avatar
Red05MCS
I agree that I need "tuner" lugs, but apparently there are none that are "tuner" lug bolts...
I will take some pictures of the wheels ASAP. In the interim, I ordered a set of longer bolts from Pilo Racing and will see what happens.
Thanks for the input!
Old Sep 6, 2005 | 07:42 PM
DaCrema's Avatar
DaCrema
is the center bore the correct diameter and shape? MINIs use hub centric (sp?) wheels.
Old Sep 7, 2005 | 05:34 AM
vader's Avatar
vader
If the seats don't match, it doesn't matter if you have longer bolts. You may grab more threads but the mismatched seats will probably damage the wheels and will for sure be a dangerous situation. I wouldn't even think about it.
Old Sep 7, 2005 | 06:24 AM
Red05MCS's Avatar
Red05MCS
Good point... I didn't even think of that. THANKS!
Old Sep 9, 2005 | 05:47 AM
Red05MCS's Avatar
Red05MCS
If I use longer lug bolts on the stock rims, will I have an interference problem?
Old Sep 9, 2005 | 05:55 PM
Passat774's Avatar
Passat774
Use your orginal equipment bolts for your orginal equipment wheels.
Does the wheel sit up tight against the mounting pad without lug bolts?
Can you balance the wheel flat against the mounting pad?
If yes than it's the bolts if no something is not right with the wheel.
Again try and take some pictures, I understand that it is very hard to sometimes to describe with words what is wrong..
Old Sep 10, 2005 | 06:58 AM
Red05MCS's Avatar
Red05MCS
Actually, at this point the bolts I got from Pilo Racing fit the wheels fine, and the wheel sits flush fine. Th e only question is whether the longer bolts will interfere with anything.
Old Sep 10, 2005 | 12:04 PM
Passat774's Avatar
Passat774
Measure how far thru the OEM bolts stick thru your factory wheels. I estimate about an inch or so.
Just make sure the new ones stick thru about that same length as well
Old Sep 10, 2005 | 11:06 PM
Red05MCS's Avatar
Red05MCS
OK... will do! Thanks for the advice!
They are all mounted on the car and seem fine. It sure will be nice when I get the hub centric rings!
Thanks again for the advice!!!!!!
Old Sep 10, 2005 | 11:53 PM
2perCooper's Avatar
2perCooper
these are tuner lug bolts
Old Sep 11, 2005 | 05:23 PM
Passat774's Avatar
Passat774
I have a set just like that from Gorilla top quality. And works great !!
Old Sep 12, 2005 | 01:01 PM
Red05MCS's Avatar
Red05MCS
Ends-up the bolts fit perfectly! Wheels went on and stayed on
I completed the auto-x and now will switch back to the OEM wheels
Thanks again for all of the support! I really appreciate it!
SosoMINI
Nov 22, 2015 03:17 PM
Mini'mon
Aug 16, 2015 04:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
Aug 12, 2015 01:24 PM
