MCS Supercharger vs JCW Supercharger
Old Aug 27, 2005 | 08:39 PM
gjpundsack's Avatar
gjpundsack
Is it true there is no differance between an '05 MCS supercharger and that in the JCW kit then the pulley size?
Old Aug 27, 2005 | 09:09 PM
kaelaria's Avatar
kaelaria
Yup.
Old Aug 27, 2005 | 10:11 PM
Tit's Avatar
Tit
Isn't the JCW charger lined with something to fortify it against "the increased pressure"...??
I thought it was the same size and flow capacity etc, just slightly modified...more accurately, over-engineered.....
Old Aug 27, 2005 | 10:14 PM
gjpundsack's Avatar
gjpundsack
I think that was true for prior model years, but not for 2005 models.
Old Aug 28, 2005 | 07:44 AM
chows4us's Avatar
chows4us
Originally Posted by kaelaria
Yup.
Thats not what JCW literature says.
"... incorporating a new pulley design, the unit spins at a higher RPM ...."
this tells me there IS something different than stock. Overengineered? maybe. But different. That would be consistent with **** comment
Old Aug 28, 2005 | 07:57 AM
Gabe's Avatar
Gabe
Here's a Q&A I did with Eaton on MotoringFile awhile back on the differences btetween the JCW Supercharger vs the standard MCS:
http://www.motoringfile.com/2004/05/...s_supercharger
Old Aug 28, 2005 | 08:00 AM
kapps's Avatar
kapps
Doesn't that just mean it has a 14.whatever % reduction pulley to spin it faster? I think the actual SC is basically the same as stock and has that coating. The coating is put along the sides so when the SC is spun for the 1st time, it eats away part of the coating where the tolerances weren't perfect and provides a much better seal. They probably decided it was worth it to just put the coating on all of them for longevity reasons and not have to worry about replacing the whole unit when fitting the JCW kit.
Old Aug 28, 2005 | 08:01 AM
chows4us's Avatar
chows4us
Thank You. Notice, however, he never really says "what" the differences are?
BTW, motoringfile rocks. Never go a day without reading it
Old Aug 28, 2005 | 10:44 AM
gjpundsack's Avatar
gjpundsack
I have studied this, talked to others and believe the prior posts on this thread corroborates for me that the only differance between the stock MCS and JCW supercharger is indeed the pulley size.
Old Aug 28, 2005 | 12:38 PM
chows4us's Avatar
chows4us
see http://www.motoringfile.com/2004/05/...s_supercharger
"Q: Is the new unit the same one on the MINI Cooper S JCW kit?
A:The unit supplied to John Cooper Works continues to be different to the unit fitted in production and the John Cooper Works package will continue to offer your readers enhanced performance without detriment to the engine durability."
Dont know what that means, can u tell?
Old Aug 28, 2005 | 12:39 PM
Tüls's Avatar
Tüls
Turbius Maximus
you are correct!
Old Aug 28, 2005 | 12:55 PM
gjpundsack's Avatar
gjpundsack
Tuls,
To me, that means the pulley is the differance.
Old Aug 28, 2005 | 01:40 PM
caminifan's Avatar
caminifan
Here is another vote for the only difference being the pulley on the JCW s/c.
Old Aug 28, 2005 | 09:23 PM
Abbett's Avatar
Abbett
The MCS water pump is driven by the supercharger shaft on the opposite side of the case from the pulley. Someone on the MINI2 forum posted that the JCW supercharger has revised gearing for the waterpump so it is not overdriven by the fitted reduction pulley. I have not seen this confirmed by a reputable source, so take it as a confirmed rumor.
dyeLucky
Sep 11, 2015 10:41 AM
Zettinger
Aug 25, 2015 04:04 PM
holkki
Factory JCW Talk (2009+)
Aug 12, 2015 10:14 AM
nomar116
Aug 10, 2015 11:24 PM
dyeLucky
Aug 7, 2015 07:10 AM
