R50/53 Whacky Washer Nozzles out of control...
Old Aug 22, 2005 | 06:45 PM
H&J's Avatar
H&J
First time I've had this problem with a CAR , my nozzles won't stay in alignment. I get the four streams hitting JUST right on the windscreen and in a day or a week at least one stream (not always the same one) is completely off target - sometimes it shoots low, sometimes high, and sometimes it just clogs. Yes, I stopped using coffee for washer fluid but still, WTF?! I know I'm stuck with this because I'm not using Locktite, just wanted to whine. Maybe I need a Prozac mist device on the dashboard when my obsessive-compulsive disorder flares up...
Old Aug 22, 2005 | 11:09 PM
namwob's Avatar
namwob
The nozzles aren't moving. You have "the crud". I think you should siphon out the old washer fluid & "the crud". Hardware stores sell clear tubing. Get clear if you don't like the taste of stale washer fluid. If you ever add water instead of washer fluid use distilled.
Old Aug 22, 2005 | 11:29 PM
H&J's Avatar
H&J
Oh man, that's too simple! I love it. You must have worked for NASA in a past life.
Makes sense - it's crud redirecting the stream!!! You'd make a great physician. Okay, when I have some free time it's new tubing and a big FLUSH.
Old Aug 23, 2005 | 09:13 PM
namwob's Avatar
namwob
New tubing? no, don't replace it. Use the tubing to siphon out the contaminated fluid.
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
Hobine
Oct 7, 2015 04:52 PM
bahman
Sep 26, 2015 07:38 PM
Ryephile
Detailing 101
Sep 16, 2015 06:32 AM
