Changing to NON Runflats
Old Aug 19, 2005 | 07:30 PM
nike61's Avatar
nike61
Hi, being a new member and MCSa owner this may seem a silly question. But I assume changing to Non Runflats does not involve any change to the MCSa electonically, does it?
I mean that when you repressure the tyres the same process applies to pushing the button near the handbrake etc
All I assume you need is a compressor or something to offset not having Runflats.
Old Aug 19, 2005 | 07:52 PM
RonR's Avatar
RonR
Hi Nike61,
I just replaced my original run flats with a set of Goodyear F-1 tires. There is no adjustment needed. The benefits for me are a quieter, smoother ride and tons of grip. I will also carry a can of Fix-A-Flat with me !!
I hope you enjoy your new non run flats !!
Best Regards,
Ron
03 MCS
Stuart, FL
Old Aug 19, 2005 | 08:15 PM
Yucca Patrol's Avatar
Yucca Patrol
you can also pick up a used full size wheel or a cooper small donut spare tire
Old Aug 19, 2005 | 10:09 PM
kaelaria's Avatar
kaelaria
It really depends on exactly what you are coming from and going to. I went from stock slites and Pirelli runflats to Exel wheels and Yokohama ES100's. The weight went down 11 lbs. per corner, but the only thing that's noticeable is better grip right off the line. The ride, noise and grip otherwise is virtually identical. I got the Continental tire fix kit (goop and compressor) from tirerack for $80.
Old Aug 21, 2005 | 01:04 AM
MGear's Avatar
MGear
Changing to non run flats does not in anyway inhibit the operation of your tire sensor, that's what you are referring to yes?
The tire pressure sensor on the Mini is a good one but its not "sophisticated" all it does is measure the rotation of the tires and can sense when one tire has 1 or 1.5 pounds pressure less than the others. It can do this becasue the tire with the lower pressure has a smaller diameter than the other tires and therefore spins at a different rate. The sensor notices the difference in spin rates and it causes the light on your dash to light up. So it works with any tire and wheel combo
Old Aug 21, 2005 | 03:07 AM
daleCarlsbad's Avatar
daleCarlsbad
Hopefully if you carry one around....you will never have to use it.
lil buddy
Old Aug 22, 2005 | 01:03 PM
Alex@tirerack's Avatar
Alex@tirerack
lil buddy
Or a Conti Comfort kit, and make those wheel and tires easy to clean up.
Alex
Kimolaoha
Dec 5, 2020 09:32 PM
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
Colt45Magnus
Sep 7, 2015 10:47 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
