17" x 7.5" et38?
Old Aug 17, 2005 | 06:41 PM
johnD's Avatar
johnD
Coordinator :: ClubMINI.ph
17" x 7.5" et38?
Does anyone have this setup? Can you please show me a pic showing how the wheel lip looks with respect to the fender arches. I am about to buy a wheel with this dimensions but I wouldn't want the wheel to be sticking out of the car. Thanks!
Johm
Old Aug 17, 2005 | 06:54 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
It does stick out but only a bit. It really depends on which tire you choose.
205/45-17 should be fine, while 215/45-17 would be a bit wider on that 7.5" rim but still not too bad. Keep the stock suspension to avoid rubbing. If you lower then the best you can do on wheel offset is about +42mm to +48mm otherwise it will rub too much. Even +42mm will rub a little under full load or with hard cornering and bumpy surfaces.
225/45-17 would be too wide.
Old Aug 17, 2005 | 07:12 PM
bonz's Avatar
bonz
Not a great picture but you should get the idea. My last set of rims were Antera 309's that were 17 x 7.5 et 35. They filled every mm of the fender well. I really did not have a rubbing problem except when a passenger was in the back seat. The rims were wrapped with Yoko avs 100's.
Nice
Old Aug 17, 2005 | 08:25 PM
onasled's Avatar
onasled
...well I would advise against it and will bet that they will rub for sure. The main reason I advise against it is that you will be limiting any future larger tire choices and forget about ever lowering the car. You really need to stick with a 45 offset on Mini wheels. 35 is just too little.
Old Aug 18, 2005 | 08:17 AM
johnD's Avatar
johnD
Darn! I was hoping to get the BBS CV's, but they only come in 38mm offsets. I already have my car dropped so I guess it's out of the question. Hmmm, maybe they do make that wheel with higher offsets. I'll go ask Alex. Thanks for the info though!
John
morriskenny
Oct 24, 2015 12:23 AM
stxmini
Tires, Wheels, & Brakes
37
Aug 6, 2013 09:48 PM
R53.0131
Jul 23, 2011 06:38 PM
newyork08
14
Feb 18, 2008 11:16 AM
