R50/53 Found a good place to mount XM Roady2
Old Jul 28, 2005 | 09:44 AM
stylin99's Avatar
stylin99
After searching and searching all over the Mini interior for a place to mount my Roady2 (XM radio) unit, I finally settled on a good spot. There are no smooth flat surfaces in the Mini so finding the ideal location was difficult that didn't have protruding wires, or was ergonomically challenging.
So here's the perfect spot! Just thought I'd share the tip if you've got one. I had to reverse the plastic mount that comes with the unit, and stapled some velcro strips to the mount's other side for it to work. Looks great, easy to read, and easy to get to. It fits in the hole where the plastic cover sits for a garage door opener. I just popped out the plastic cover and there's plenty of room to run wires and put a mount in there.
Old Jul 28, 2005 | 10:35 AM
sagworks's Avatar
sagworks
running with scissors
Great Idea
Is it really easy to see the screen as the driver? It is a mighty fine idea....
Old Jul 28, 2005 | 10:49 AM
stylin99's Avatar
stylin99
Yep. Because I used the included plastic swivel mount (just turned it around reversed) I can tilt it from side to side or up and down to face me, or the passenger.
Old Jul 29, 2005 | 02:34 PM
spec35's Avatar
spec35
Does the XM require a special ant.?
Etrain
16
Aug 5, 2024 04:37 AM
blackie
Jan 18, 2017 09:56 PM
Zettinger
Aug 25, 2015 04:04 PM
JPMontes3
Aug 23, 2015 01:26 AM
JPMM
Aug 13, 2015 12:01 PM
