boot door/hatchback problems
Old Jul 12, 2005 | 09:27 PM
c615586's Avatar
c615586
I'm not sure if this problem has been posted before... a simple search didn't yield any quick answers, so here goes:
The hatchback/boot door/boot lid on 2004 MCS (17500 miles) intermittently fails to close completely--or at least my car thinks the door is open and leaves the dome light on with the warning lamp lit on the speedometer.
This seems to occur in warmer weather and when the car has been sitting outside in the sunshine. When the car is left overnight or in my garage where it is relatively cool, the warning light and dome light never come on.
I've also noticed a mild creaking noise from the rear of the car as I drive over speed bumps when the weather is warm, which I presume may be related.
Sooo... is this a sensor problem or is the door actually loose (it still shuts completely even when the warning light comes on) and is there an easy fix/adjustment or do I need to take to my dealer?
Thanks in advance,
vin
Old Jul 12, 2005 | 09:56 PM
myzamboni's Avatar
myzamboni
I too have this exact same problem on my 2004 at 11500. It is intermittent, so the dealer could not duplicate the occurence. I can tell when my boot is shut properly so I just ignore the light if it comes on.
Old Jul 12, 2005 | 10:00 PM
lotsie's Avatar
lotsie
Thanks in advance,
vin
I sort of had the same issue, only in the cold. Turned out to be the latch and stricker(what the latch in the hatch locks onto)
Hey that's like Dr.Suess,sorry.
I would have to slam the hatch shut, to get the dash light to go out, but my dome light never came on.
But try this, there are 2 rubber stops about 1/2 way up the opening. You can adjust them,turning them to the right puts less pressure on the hatch, turning to the left puts more pressure on the hatch.Turn them all the way to the right, screwing them in all the way, then see if you still have the problem.
Now with them screwed all the way in the hatch may rattle. So then turn them to the left a 1/4 turn till the rattle stops. If the rattle stops, but the light problem returns, well if this works, then you need to go to the dealer and get a new latch/stricker
Hope this helps:smile:
Old Aug 11, 2005 | 10:05 PM
1FSTMINI's Avatar
1FSTMINI
Newer black latch will fix the problem the old chrome one is having.
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
LordOfTheFlies
Oct 19, 2015 05:02 PM
Chasp
Aug 22, 2015 01:27 PM
speedbird_1
Aug 15, 2015 04:44 PM
