D Stock Kumho V710 215/40 16 Pressures?
Old Jun 13, 2005 | 06:57 PM
Tirewarmer's Avatar
Tirewarmer
Anyone have a good starting point for V710 pressures? I am getting my tires mounted tomorrow and have my first event this weekend on them, SE Divisionals at Gwinnet County Fairgrounds. I'm afraid I'll start to low in the front and tear up the outside edges. What kind of pressures is everyone running in the rear to get rotation? Any and all advice is greatly appreciated.
Joe
Old Jun 14, 2005 | 05:48 AM
satay-ayam's Avatar
satay-ayam
On asphalt, I've been using like 42psi in front and about 33psi in rear. However, if it's cold/nasty (I live in MN, and it actually snowed at our second autocross this year), the 33psi in the rear gives some pretty stupid oversteer. I try have run as low as like 28psi back there in foul weather (and will run the fronts at maybe 40).
I've only run one concrete event on them, and I ran about 45psi front and the usual 33psi rear. 45psi might be too low for concrete, but again I don't have a whole lot of data points
This is on an HS Cooper, though, not a Cooper S. So far, on mostly asphalt, I haven't gotten obnoxious wear.
Have fun mounting them I helped my tire guy get them on my wheels, and it was a <fill in your own explative here>
bahman
Feb 14, 2016 10:29 AM
Oct 1, 2015 12:13 PM
eliseo1981
Sep 30, 2015 07:57 PM
Emnotek
Sep 29, 2015 07:37 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
