bad vibrations
Old May 24, 2005 | 08:14 PM
peterwhit's Avatar
peterwhit
bad vibrations
I recently installed 18x7.5 Velox VX Nova with 225-40-18 Sumitomo HTZ2s. I ordered the tires form the tire rack and had sears do the mounting balancing and alignment. Car feels great except around 50mph-60 the steering wheel vibrates back and forth. The car does not pull to one side or the other, just vibration. It loooked like the wheels had hub centric caps but maybe one or more of them are bad. Any help would be great thanks.
Old May 24, 2005 | 08:26 PM
meanboy's Avatar
meanboy
Did they ever feel okay? If so, maybe, one of the weights fell off of the rim. That happened to me before.
Old May 24, 2005 | 09:00 PM
peterwhit's Avatar
peterwhit
not really i had them aligned the 2nd day after having them on and the vibrations kicked in at 50 instead of 40 mph.
Old May 24, 2005 | 10:13 PM
meanboy's Avatar
meanboy
I guess I would go back to sears and ask them to check the balance. Or ask them to inspect the hubcentric rings.
Old May 25, 2005 | 05:22 PM
kenchan's Avatar
kenchan
I would first check to see if you have all four centering rings.
Then re-torque the lugs in a cross pattern.
If they still vibrate, bring them to a tireshop that has a
Hunter balancer. :smile:
Old May 26, 2005 | 08:39 AM
Alex@tirerack's Avatar
Alex@tirerack
Use this to locate a competent shop in your area Recomended Installer program.
Alex
minieater
Oct 28, 2015 02:15 PM
Fordgt4
Oct 10, 2015 10:42 AM
drum6g
Sep 29, 2015 01:15 PM
jennster
Sep 28, 2015 06:19 PM
Adam Bradbury
Sep 28, 2015 04:15 PM
