Timing pull questions
Old May 23, 2005 | 06:39 PM
kaelaria's Avatar
kaelaria
I hooked up a Carchip E/X tonight and did some runs. I have the JCW intake, a 15% pulley and MTH's latest version. I have IK22's ready to put in tomorrow, and will do nother run.
With the stock plugs in, at WOT from 1st, timing is being pulled to -5 deg. Does this indicate retard for knock, indicating the need for the lower heat range plugs? How much of a rise in timing should I see tomorrow if so?
This should be a good test for the experts as well
Old May 23, 2005 | 07:38 PM
002's Avatar
002
I also have mth and a scanner. When coasting mine will be between 30-40. Then when at full throttle it drops to 20 and works it way up to 30. Every time I've checked it that has been the pattern. I have a 15% pulley, intake and exhaust and have tried it with stock plugs, stock range autolite and ik22. Also, I have never seen a negative number on my car.
Old May 23, 2005 | 07:50 PM
kaelaria's Avatar
kaelaria
I wonder if this carchip is gathering the data correctly then. My ranges are way up there when coasting though. I'll keep playing with it.
Old May 23, 2005 | 07:57 PM
tradiuz's Avatar
tradiuz
MTH Specialist
Originally Posted by kaelaria
I hooked up a CarTune E/X tonight and did some runs. I have the JCW intake, a 15% pulley and MTH's latest version. I have IK22's ready to put in tomorrow, and will do nother run.
Cartune E/X?
Old May 23, 2005 | 08:00 PM
minimonkey's Avatar
minimonkey
CarTune E/X?
Do you mean CarChip E/X?
Old May 23, 2005 | 08:06 PM
kaelaria's Avatar
kaelaria
Yeah - brain fart - edited
Old May 23, 2005 | 08:09 PM
minimonkey's Avatar
minimonkey
Okay - I have that product too... really nice. Question: How are you getting it to record the engine "timing"? I didn't know it would do that. You know the instruction book (?what?) or lack of one... didn't tell me enough.
Old May 23, 2005 | 08:14 PM
kaelaria's Avatar
kaelaria
The standard Carchip doesn't let you choose parameters to log, the E/X lets you choose up to 4 from a list of 20 or so. Timing is one of them.
Old May 24, 2005 | 06:50 AM
kaelaria's Avatar
kaelaria
OK, here's a chart from this morning coming into work, this is still with the stock plugs. What I don't understand is why the timing is being pulled not on accelleration, but on off-throttle. Does this look right? Blue is speed, purple is timing advance/retard.
Old May 24, 2005 | 07:20 AM
CC's Avatar
CC
I'd bet...
the retarding during decel or off-power-demand periods is some sort of emission function...lower heat to curb nitrogen oxide artifacts...just a WAG.
Old May 24, 2005 | 07:24 AM
kaelaria's Avatar
kaelaria
I wonder if that's what's casuing the overrun burble?
Old May 24, 2005 | 07:48 AM
CC's Avatar
CC
I never thought of that...
mainly because I don't have an S and my MC doesn't burble. I guess it could be that, or the exhaust, or both. I wouldn't begin to know how to disable the function to isolat it...probably in the chip profile.
Old May 24, 2005 | 07:59 AM
CC's Avatar
CC
Just had a thought...
and of course, the usual acompanying headache lol...I'm real new to the MINI world and I've reached the age where I don't like to get grease under my fingernails, so I haven't really looked at the car the way I used to. That said, I have a question...is the exhaust system on my MC the same as on your S? I doubt it but if they are, then the burble question doesn't pend on the exhaust (unless of course mine DOES burble and my old ears lost that frequency in the spectrum lol)
Old May 24, 2005 | 08:41 AM
kaelaria's Avatar
kaelaria
No, they aren't the saame.
Old May 24, 2005 | 08:51 AM
mattharris75's Avatar
mattharris75
I would say this is almost certainly the cause of the burble. That was my guess anyway, before you logged these reults. This just confirms it. When we tune 'big turbo' VW's we have similar burbling results and I believe for the same reason. Obviously the 2005's had this programmed in intentionally.
Old May 24, 2005 | 09:47 AM
kaelaria's Avatar
kaelaria
OK, plugs are changed to the IK22's. I'll do another run on the way home. Temps will be about 15 deg hotter and humidity is about 100% today.
Here are the stock plugs after 3000 miles. 1500 stock, 1000 with an intake and pulley, 500 with intake, pulley and MTH:
Attached Thumbnails Timing pull questions-plugs1.jpg   Timing pull questions-plug2.jpg
Old May 24, 2005 | 02:55 PM
kaelaria's Avatar
kaelaria
Well, with the plugs switched to the colder IK22's, and the weather about 15 deg hotter (85) and humidity in the upper 90's, there is absolutely no difference from the stock plugs, with a JCW intake, 15% pulley and MTH software. Butt-dyno says identical, logs show the same readings.
At least the plugs were cheap, and I have perfectly good OEMs to put in when these wear out.
Cereall
Sep 5, 2019 06:05 PM
elightbo
Aug 17, 2015 01:50 PM
nomar116
Aug 10, 2015 11:24 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
