Drivetrain That annoying piece of plastic behind the air intake box
Old May 21, 2005 | 05:33 AM
L8RG8R's Avatar
L8RG8R
Does anyone have an owner's manual that details how to remove the piece of plastic behind the air intake box? I am trying to remove the restriction caused by this piece in order to pull more air through the windshield vents as the tiny hole provided doesn't really do much. Any help is much appreciated.
Old May 21, 2005 | 05:50 AM
norm03s's Avatar
norm03s
Welcome to NAM
Just go here;
https://www.northamericanmotoring.co...ead.php?t=4133
Also in the upper right there is a search engine.
Old May 21, 2005 | 07:22 AM
obehave's Avatar
obehave
I've always been a bit suspicious of the punching holes or removing this piece. It does isolate under hood temps and fumes from the air intake for the HVAC system.
Heat and smell is not what I want to suck into the cabin of my car.
Old May 21, 2005 | 08:51 AM
L8RG8R's Avatar
L8RG8R
Thanks!
thanks for the link. new to this whole thread posting thing. the instructions were perfect. more flow...and no added smell in the cabin.
Old May 21, 2005 | 09:12 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Just a note that removal or alteration of this plastic piece is not legal for SCCA Solo II stock class events.
For street driving and track use it is fine.
Don't forget to store it in a safe place where you can find it.
I've got a garage full of spare OEM MINI parts now.
Old May 21, 2005 | 11:31 AM
flyboy2160's Avatar
flyboy2160
i agree, especially if you've got CO in those fumes. soon i'll cut an oblong hole through both walls then seal the gap with soft silicone foam so there's no path into the cabin.
Old May 21, 2005 | 11:38 AM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
I believe cabin intake is only on the other side. Thats where your cabin filter is.
Old May 21, 2005 | 12:02 PM
obehave's Avatar
obehave
If you look closely you'll see that both plenum areas are connected. It's where your brake lines run from the master cylinder to control module on the US passenger side.
Old May 21, 2005 | 12:22 PM
th3118's Avatar
th3118
Oh, you're right! I guess that cabin filter works good, I've never smelled any fumes in two years.
Old May 21, 2005 | 12:31 PM
obehave's Avatar
obehave
It's what you can't smell that'll kill you.
That said though it is just my opinion
chrisx18240
26
Mar 16, 2022 09:56 AM
W0TM8
Dec 19, 2019 07:50 AM
kazyn
Oct 25, 2019 02:34 PM
theblackfalcon
Aug 26, 2015 09:18 AM
