Engine knocking
Old May 19, 2005 | 08:20 AM
Oban2002's Avatar
Oban2002
Engine knocking
I posted this in another forum with no response, so I'll try again....
I have a Jan 05 build MCS with the JCW engine upgrade. When I start the car, morning temps in DC are in the 50s now, I hear mild knocking from the engine. After a few minutes this goes away. Is this anything to worry about or is it normal?
Thanks!
Oban
Old May 19, 2005 | 08:34 AM
fred3's Avatar
fred3
Hmmm...
Low octance gas?
Old May 19, 2005 | 08:35 AM
kaelaria's Avatar
kaelaria
Are you sure it's not the 'cold start low idle' that's been reported in other threads lately? Does your idle drop around 500 and almost stall the engine when first starting? I doubt you are actually hearing knock.
Old May 19, 2005 | 08:39 AM
camelpilot's Avatar
camelpilot
what quality gas do you put in it?
Old May 19, 2005 | 08:41 AM
YellowBellyMini's Avatar
YellowBellyMini
I know this is an obvious solution...but no matter what problem I was having, and whether or not I knew how to fix it...I took my car to the dealer and made them fix it for me. Maybe thats because I was new to the whole 'warranty' thing... That would be my recommendation to you, especially if you are not familiar with the innards of a car. Also, cold start problems and the yo-yo effect have been known to be fixed by software updates, and if that applies to your problem, i'm not sure...but its best to let the dealer fix it, especially since yours is so new.
Do you put any additives like octane boost in your gas...because my father did that with his mercedes when only 91 was available and he needed 93, and it caused similar problems, and then he found out he was not supposed to put anything like that in the gas tank...the car knew it was there.
Old May 20, 2005 | 06:15 PM
k-huevo's Avatar
k-huevo
Oban, of course you should contact the dealer who installed the JCW kit and share your concerns.
This may not be a relevant story, but here’s an example of the kind of mistake that can occur when the kit is installed. Two weeks ago there was a JCW at the local dealership with a broken camshaft. The camshaft bearing cap bolts had not been properly torqued resulting in the break.
Old May 21, 2005 | 06:26 AM
mikem53's Avatar
mikem53
They should have made this a factory installed option and not a dealer option.. That's one reason why I won't order the JCW package.
STR3T
May 23, 2016 03:27 AM
flredmini
Apr 5, 2016 06:21 AM
silence2-38554
Nov 12, 2015 09:39 AM
David.R53
Sep 1, 2015 06:49 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
