Centerbore rings won't come out
Those centerbore rings are stuck on the rotors at the moment, could spin freely (after bashing them) but it won't come off the rotor. Any ideas short of pulling the rotors out and bash it to death or drill holes onto the centerbore rings itself to ply it out?
Originally Posted by Thameth
Get a thing screwdriver between the ring and the hub and pry it off. Just make sure not to pry too hard or you'll damage them if they're composite plastic.
Now what the heck is that channel plier thing? I might go grab one for the sake to pull it out.
Originally Posted by petecrosby
I have managed to remove them in the past using a LARGE pair of channel-lock pliers. This works best after the car has been sitting for several hours.
The plastic rings will deform from the heat especially. I grind down the inner surface of both metal and plastic rings that I use especially on the right front wheel and that helps to lessen the problem. If you can spin the ring then it is loose but binding. The pliers will work- just use a large one.
Careful if you do use a screwdriver to pry out the ring, you can damage your rotor in the process.
Of note- my deformed and ground down rings are doing quite well. Once deformed they seem to resist further problems. Changing to brake rotors and pads that can take heat better or installing a brake duct doesn't hurt.
I've got to say that I think hubcentric rings are simply evil. I've seen all kinds of problems with them at the track: missing, doubled up, bent/kinked/broken, etc.
I've got more sets of wheels in the garage than I care to think about (snows x 2 sets, track x 2, more) and not one of them requires rings.
Just say NO! Buy wheels that are machined to fit without kludgy hubcentric rings.
Neil
05 MCS
Neil
05 MCS
Alex
Originally Posted by Pankeyguy
Are there acceptable ways of modifying the rings without relegating them to uselessness?
It's a slow process but I can get a good fit if I take my time.
I like having a full selection of possible wheels and gladly use the rings as needed.
The selection of perfect fit MINI wheels is too narrow for my tastes and needs.
If you are doing only street driving it really isn't a problem to have the rings.
Just make sure that any garage that removes your wheels doesn't loose the rings.
Have tried all your suggestions (and my gf was scratching her head major when I ran into the house quite dirty and pulled the vinegar out of the kitchen..), got 2 out but the rear ones still won't come off. I've even gone to drill a slot into them so I could pry them out but it still wouldn't come off.
Any other ideas? I think I might need to get a garage to cut them into 2 and that's probably the only way to sort it out....
I love my new wheels (it doesn't use rings thank goodness) but only got 2 up the front and the rear is still those old, ugly Taiwanese stuff...
lesson learnt - you get what you paid for.
Originally Posted by Alex@tirerack
Thats rough when you vehcle fitment is SO close to many other cars. Your immidiatley narrowing your choices to "mini specific" manufactures .
Alex
Alex
BTW, I'm a local Indiana customer. All my BMW wheels came from TR in SB, and they all fit correctly with no spacers or hubcentric rings. I'm not inclined to settle for less for the Mini.
Neil
05 MCS
96 M3
03 525iT
77 MGB
Originally Posted by NeilM
I don't think that's too much to ask,
15x7 et40 Centerbore
Mini Cooper 56
Mazda Miata 54
Honda Civic 56.15
Dodge Neon 57
These could all be the same piece with rings used - or 4 diffrent part #'s if they were bored specifically.
Why dont we just bore blanks? Machien work should allways be done prior to paint, to keep the finish intact.
Alex
How long did you soak it in vinegar? You have to keep dripping every minute or so for 15min -30min. Yep, time consuming but it should work.
These could all be the same piece with rings used - or 4 diffrent part #'s if they were bored specifically. Alex
Not this customer ;-)
Neil
05 MCS
Yep, but that's life in the wheel biz. I fully understand how hubcentric rings make a vendor's life easier, but it's at the cost of pushing a kludge onto the customer.
Neil
05 MCS
Neil
05 MCS
If there was noticable difference in function, that would be another
story.
I appreciate manufacturers using their heads to provide the cost benefit
to the end user by offering such option.
Maybe that's the reason, it was soaked in vinegar for 15 minutes only. I'll go back and try again
also tap it gently from time to time with a small hammer to loosen the
rust under the ring.
Well I gave up in vein and let the guys that sold me the tires to sort it out. They kind of destroyed the rings (still re-usable up to a point) by getting a huge hammer, a piece of metal and start hammering the living daylight out of the rings. It did pop out at last after bashing them for almost 15 minutes on each corner.
I suppose soaked the rings with vinegar probably made their job easier
thanks Ken.
thanks Ken.
If there was noticable difference in function, that would be another story.
Neil
(Who has never had to soak his properly fitting wheels in vinegar to get them off.)
who are you again? jk
ive never had to soak my entire wheel...
So should I take it that you haven't actually read the rest of this thread?
Neil
Neil
