Track Tire choices?
I just got a set of the RA1s. Have not tracked them yet but I tried them on the street and LOVE'M. They are one of the hot choices out there now due to their endurance. I hear they are not the best choice for autoX because they take a bit longer to heat up.
I got mine from here http://www.bmwwheels.com/ Great prices and excellent delivery. I got the 205/40/17 as this is what the JCW series guys are using. I think I could have fit the 235/40/17 though and I may try.
I had mine shaved to 4/32. The website I posted has all the info on dimension of every size here http://www.bmwwheels.com/ra1.pdf
I also here that un-shaved they are excellent wet choice.
225/45/17 Michelin Pilot Sport CUP - now thats a long lasting road course tire!
225/45 take some more seroius fender work to fit, but the tire possibities are much greater. Its allso a bit tall, at 25.1 inches. I know of a few using this!
Alex
Alex
Originally Posted by DDMini
alex,
what kind of fender work is needed? what wheel offset is best for 225/45/17?
/thanks
/thanks
For a stock ride height, very little trimming is needed. You need to trim away some of the rear plastic wells out near the flairs.
Lowered you will need to trim a good amount of the rear plastic wells along with some metal seam grinding. The fronts might need a bit of the fender flair lip trimmed away.
if the stock ride height was kept, and the fattest tire possible was to fit on the car, what offset would be best?
would this offset be different for a car with 0.5-1.0 inches of drop?
how do you fill up the mini fenders like a M3?
If wheel offset is +45mm you'd get some rubbing and need to do some trimming.
As you lower your MINI you get even less clearance and more rubbing.
You can fill out your fenders by selecting coilovers with adjustable height or using tires that have slightly larger tire diameter but not more than 215mm wide.
minihune,
the 235s sound tasty, is the 8 inch wide rim needed to keep the side wall as straight as possible?
i haven't picked rims yet, what offset would be ideal for 17x8? when you say +45, do you mean over 45mm, ie., larger number +46,47.....? to move the tire closer to the inside of the fenderwell?
i bet the mini is fun over there, i went to UH, shipped a MGB over while i was in school. the road to sandy beach would be fun, and around to makaha and bellows.
235 in a street tire would be a tough fit. They might start to hit the trailing arm at this point.
I met someone at the track that was using 225/45/17s with stock ride height. I felt under his wheel well and there were rubs in the plastic. So 235s would seem to be just too big without some clearance mods and camber adjustments.
A wider tire does you no good at stock ride height, IMHO. Lower the car and go with a lightweight combo of wheel and tire, as that’s the biggest performance gainer in wheels and tires.
minihune,
Remember that a wider rim has to fit both the inside and the outer wheel arch areas so wheel offset becomes critical. 17x7" rims allow for a better range of wheel offsets that will fit.
eatsleepautox
Oct 30, 2015 06:46 AM
ki7hy
Aug 12, 2015 07:07 PM
